[PostGIS] #5763: Berrie64 PostgreSQL support not building with XML support
PostGIS trac at osgeo.org
Fri Jul 12 13:20:06 PDT 2024
  Reporter:  robe        |      Owner:  robe
      Type:  defect      |     Status:  closed
  Priority:  medium      |  Milestone:  PostGIS 3.5.0
 Component:  management  |    Version:  master
Resolution:  fixed       |   Keywords:
Changes (by robe):
 * status:  new => closed
 * version:  3.4.x => master
 * resolution:   => fixed
Comment:
 okay might be some change in PG17 and I had switched berrie to test
 against PG17/PG18.
 I had to explicitly add in the postgresql configure --with-libxml for it
 to build with xml support even though xml is detected without specifying
 path.
 I'll close this out now and reopen if it is still an issue.
 I'm going to test meson building perhaps against PG18
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5763#comment:1>
