[PostGIS] #5764: PostGIS regress issues when building PostgreSQL with meson
trac at osgeo.org
Sun Jul 14 22:56:23 PDT 2024
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.0
Component: install | Version: master
Keywords: |
These could be specific to how I configured meson on each system.
On debbie, I built PostgreSQL 17 with this:
export PG_VER=17
cd pg17git
rm -rf ../meson-pg${PG_VER}-build
meson setup ../meson-pg${PG_VER}-build && cd ../meson-pg${PG_VER}-build
meson configure -Dcassert=true
--prefix=${WORKSPACE}/rel/pg${PG_VER}w${OS_BUILD}
meson compile
rm -rf ${WORKSPACE}/rel/pg${PG_VER}w${OS_BUILD}
meson install
My autoconf build works fine regressing against postgis master branch,
however this meson build one fails at loader tests:
https://debbie.postgis.net/job/PostGIS_Regress/30767/consoleFull
01:31:47 PostGIS is now configured for x86_64-pc-linux-gnu
01:31:47
01:31:47 -------------- Compiler Info -------------
01:31:47 C compiler: gcc -std=gnu99 -g -O2 -fno-math-errno
-fno-signed-zeros -Wall -O2
01:31:47 C++ compiler (Wagyu): cc -std=c++11 -x c++
01:31:47 C++ compiler (FlatGeobuf): cc -std=c++11 -x c++
01:31:47 CPPFLAGS:
-I/var/lib/jenkins/workspace/geos/rel-3.13w64/include
-I/usr/include/libxml2 -I/usr/include -I/usr/include/json-c -DNDEBUG
01:31:47 LDFLAGS: -lm
01:31:47 SQL preprocessor: /usr/bin/cpp -traditional-cpp -w -P
-Upixel -Ubool
01:31:47 Archiver: gcc-ar rs
01:31:47
01:31:47 -------------- Additional Info -------------
01:31:47 POSTGIS lib file includes minor: ENABLED
01:31:47 Interrupt Tests: ENABLED
01:31:47
01:31:47 -------------- Dependencies --------------
01:31:47 GEOS config:
/var/lib/jenkins/workspace/geos/rel-3.13w64/bin/geos-config
01:31:47 GEOS version: 3.13.0dev (31300)
01:31:47 GDAL config:
/var/lib/jenkins/workspace/gdal/rel-3.4w64/bin/gdal-config
01:31:47 GDAL version: 3.4.3
01:31:47 SFCGAL config: /usr/bin/sfcgal-config
01:31:47 SFCGAL version: 1.3.8
01:31:47 PostgreSQL config:
/var/lib/jenkins/workspace/pg/rel/pg17w64/bin/pg_config
01:31:47 PostgreSQL version: PostgreSQL 17beta2
01:31:47 PROJ version: 7.2.1 (70201)
01:31:47 Libxml2 config: /usr/bin/xml2-config
01:31:47 Libxml2 version: 2.9.14
01:31:47 JSON-C support: yes
01:31:47 protobuf support: yes
01:31:47 protobuf-c version: 1003003
01:31:47 PCRE support: not found
01:31:47 Perl: /usr/bin/perl
01:31:47
01:31:47 --------------- Extensions ---------------
01:31:47 PostgreSQL EXTENSION support: enabled
01:31:47 PostGIS Raster: enabled
01:31:47 PostGIS Topology: enabled
01:31:47 SFCGAL support: enabled
01:31:47 Address Standardizer support: disabled
This error is for all loader and dumper tests
01:34:49 regress/loader/Point ........ failed (dumper geog test: dumping
loaded table:
/var/lib/jenkins/workspace/postgis/tmp/3_5_pg17w64/dumper.err)
01:34:49
01:34:49 could not connect to server: No such file or directory
01:34:49 Is the server running locally and accepting
01:34:49 connections on Unix domain socket
"/var/run/postgresql/.s.PGSQL.3617"?
01:34:49
01:34:49
01:34:49 regress/loader/PointM ........ failed (dumper geog test: dumping
loaded table:
01:34:49
01:34:49
01:34:56 regress/dumper/mfiledmp .. failed (dumping:
/var/lib/jenkins/workspace/postgis/tmp/3_5_pg17w64/dumper-mfiledmp.err)
01:34:56
01:34:56 could not connect to server: No such file or directory
01:34:56 Is the server running locally and accepting
01:34:56 connections on Unix domain socket
On my windows new chain I have configured with meson, autoconf again works
more or less okay(there are some regress failures but more to do with my
new chain), however meson build completely falls on its face out of the
gate and fails to install the extensions. strk thinks it's something with
sed or grep, perhaps the use of PGXS is messing with it.
mkdir -p
'C:/ming64/projects/POSTGR~1/rel/pg17w64/share/contrib/postgis-3.5'
/bin/sh
C:/ming64/projects/POSTGR~1/rel/pg17w64/lib/pgxs/src/MAKEFI~1/../../config
/install-sh -c -m 644 postgis_comments.sql raster_comments.sql
topology_comments.sql sfcgal_comments.sql
'C:/ming64/projects/POSTGR~1/rel/pg17w64/share/contrib/postgis-3.5/'
make[2]: Leaving directory '/projects/postgis/postgis-git/doc'
mkdir -p /projects/postgis/liblwgeom-3.5w64/share/man/man1
for f in man/shp2pgsql.1 man/pgsql2shp.1 man/pgtopo_export.1
man/pgtopo_import.1 man/postgis.1 man/postgis_restore.1; do \
/usr/bin/install -c -m 644 $f
/projects/postgis/liblwgeom-3.5w64/share/man/man1/`basename $f`; \
done
make[1]: Leaving directory '/projects/postgis/postgis-git/doc'
---- Making install in extensions
make[1]: Entering directory '/projects/postgis/postgis-git/extensions'
for DIR in postgis postgis_tiger_geocoder postgis_topology postgis_sfcgal;
do \
echo "---- Making install in ${DIR}"; \
make -C "${DIR}" install || exit 1; \
done
---- Making install in postgis
make[2]: Entering directory '/projects/postgis/postgis-
git/extensions/postgis'
mkdir -p 'C:/ming64/projects/POSTGR~1/rel/pg17w64/share/extension'
mkdir -p "C:/ming64/projects/POSTGR~1/rel/pg17w64/share/extension"
/bin/sh ../../config/install-sh -c -m 644 "sql/postgis--ANY--3.5.0dev.sql"
"C:/ming64/projects/POSTGR~1/rel/pg17w64/share/extension/postgis--ANY--
3.5.0dev.sql"
/bin/sh: ../../config/install-sh: No such file or directory
make[2]: *** [../upgrade-paths-rules.mk:26: install-upgrade-paths] Error
127
make[1]: *** [Makefile:36: install] Error 1
make[1]: Leaving directory '/projects/postgis/postgis-git/extensions'
make: *** [GNUmakefile:27: install] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5764>
