[PostGIS] #5764: PostGIS regress issues when building PostgreSQL with meson
PostGIS trac at osgeo.org
Sun Jul 14 22:57:42 PDT 2024
  Reporter:  robe     |      Owner:  strk
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.5.0
 Component:  install  |    Version:  master
Resolution:           |   Keywords:
Description changed by robe:
Old description:
> These could be specific to how I configured meson on each system.
> On debbie, I built PostgreSQL 17 with this:
> export PG_VER=17
> cd pg17git
> rm -rf ../meson-pg${PG_VER}-build
> meson setup ../meson-pg${PG_VER}-build && cd ../meson-pg${PG_VER}-build
> meson configure -Dcassert=true
> --prefix=${WORKSPACE}/rel/pg${PG_VER}w${OS_BUILD}
> meson compile
> rm -rf ${WORKSPACE}/rel/pg${PG_VER}w${OS_BUILD}
> meson install
> My autoconf build works fine regressing against postgis master branch,
> however this meson build one fails at loader tests:
> https://debbie.postgis.net/job/PostGIS_Regress/30767/consoleFull
> 01:31:47   PostGIS is now configured for x86_64-pc-linux-gnu
> 01:31:47
> 01:31:47  -------------- Compiler Info -------------
> 01:31:47   C compiler:           gcc -std=gnu99 -g -O2 -fno-math-errno
> -fno-signed-zeros -Wall -O2
> 01:31:47   C++ compiler (Wagyu): cc -std=c++11 -x c++
> 01:31:47   C++ compiler (FlatGeobuf): cc -std=c++11 -x c++
> 01:31:47   CPPFLAGS:
> -I/var/lib/jenkins/workspace/geos/rel-3.13w64/include
> -I/usr/include/libxml2 -I/usr/include -I/usr/include/json-c  -DNDEBUG
> 01:31:47   LDFLAGS:               -lm
> 01:31:47   SQL preprocessor:     /usr/bin/cpp -traditional-cpp -w -P
> -Upixel -Ubool
> 01:31:47   Archiver:             gcc-ar rs
> 01:31:47
> 01:31:47  -------------- Additional Info -------------
> 01:31:47   POSTGIS lib file includes minor:   ENABLED
> 01:31:47   Interrupt Tests:   ENABLED
> 01:31:47
> 01:31:47  -------------- Dependencies --------------
> 01:31:47   GEOS config:
> /var/lib/jenkins/workspace/geos/rel-3.13w64/bin/geos-config
> 01:31:47   GEOS version:         3.13.0dev (31300)
> 01:31:47   GDAL config:
> /var/lib/jenkins/workspace/gdal/rel-3.4w64/bin/gdal-config
> 01:31:47   GDAL version:         3.4.3
> 01:31:47   SFCGAL config:        /usr/bin/sfcgal-config
> 01:31:47   SFCGAL version:       1.3.8
> 01:31:47   PostgreSQL config:
> /var/lib/jenkins/workspace/pg/rel/pg17w64/bin/pg_config
> 01:31:47   PostgreSQL version:   PostgreSQL 17beta2
> 01:31:47   PROJ version:         7.2.1 (70201)
> 01:31:47   Libxml2 config:       /usr/bin/xml2-config
> 01:31:47   Libxml2 version:      2.9.14
> 01:31:47   JSON-C support:       yes
> 01:31:47   protobuf support:     yes
> 01:31:47   protobuf-c version:   1003003
> 01:31:47   PCRE support:         not found
> 01:31:47   Perl:                 /usr/bin/perl
> 01:31:47
> 01:31:47  --------------- Extensions ---------------
> 01:31:47   PostgreSQL EXTENSION support:       enabled
> 01:31:47   PostGIS Raster:                     enabled
> 01:31:47   PostGIS Topology:                   enabled
> 01:31:47   SFCGAL support:                     enabled
> 01:31:47   Address Standardizer support:       disabled
> This error is for all loader and dumper tests
> 01:34:49  regress/loader/Point ........ failed (dumper geog test: dumping
> loaded table:
> /var/lib/jenkins/workspace/postgis/tmp/3_5_pg17w64/dumper.err)
> 01:34:49
> 01:34:49 could not connect to server: No such file or directory
> 01:34:49        Is the server running locally and accepting
> 01:34:49        connections on Unix domain socket
> "/var/run/postgresql/.s.PGSQL.3617"?
> 01:34:49
> 01:34:49
> 01:34:49  regress/loader/PointM ........ failed (dumper geog test:
> dumping loaded table:
> 01:34:49
> 01:34:49
> 01:34:56  regress/dumper/mfiledmp .. failed (dumping:
> /var/lib/jenkins/workspace/postgis/tmp/3_5_pg17w64/dumper-mfiledmp.err)
> 01:34:56
> 01:34:56 could not connect to server: No such file or directory
> 01:34:56        Is the server running locally and accepting
> 01:34:56        connections on Unix domain socket
> On my windows new chain I have configured with meson, autoconf again
> works more or less okay(there are some regress failures but more to do
> with my new chain), however meson build completely falls on its face out
> of the gate and fails to install the extensions.  strk thinks it's
> something with sed or grep, perhaps the use of PGXS is messing with it.
> mkdir -p
> 'C:/ming64/projects/POSTGR~1/rel/pg17w64/share/contrib/postgis-3.5'
> /bin/sh
> C:/ming64/projects/POSTGR~1/rel/pg17w64/lib/pgxs/src/MAKEFI~1/../../config
> /install-sh -c -m 644  postgis_comments.sql raster_comments.sql
> topology_comments.sql sfcgal_comments.sql
> 'C:/ming64/projects/POSTGR~1/rel/pg17w64/share/contrib/postgis-3.5/'
> make[2]: Leaving directory '/projects/postgis/postgis-git/doc'
> mkdir -p /projects/postgis/liblwgeom-3.5w64/share/man/man1
> for f in man/shp2pgsql.1 man/pgsql2shp.1 man/pgtopo_export.1
> man/pgtopo_import.1 man/postgis.1 man/postgis_restore.1; do \
>         /usr/bin/install -c -m 644 $f
> /projects/postgis/liblwgeom-3.5w64/share/man/man1/`basename $f`; \
> done
> make[1]: Leaving directory '/projects/postgis/postgis-git/doc'
> ---- Making install in extensions
> make[1]: Entering directory '/projects/postgis/postgis-git/extensions'
> for DIR in postgis postgis_tiger_geocoder postgis_topology
> postgis_sfcgal; do \
>         echo "---- Making install in ${DIR}"; \
>         make -C "${DIR}" install || exit 1; \
> done
> ---- Making install in postgis
> make[2]: Entering directory '/projects/postgis/postgis-
> git/extensions/postgis'
> mkdir -p 'C:/ming64/projects/POSTGR~1/rel/pg17w64/share/extension'
> mkdir -p "C:/ming64/projects/POSTGR~1/rel/pg17w64/share/extension"
> /bin/sh ../../config/install-sh -c -m 644 "sql/postgis--ANY--
> 3.5.0dev.sql"
> "C:/ming64/projects/POSTGR~1/rel/pg17w64/share/extension/postgis--ANY--
> 3.5.0dev.sql"
> /bin/sh: ../../config/install-sh: No such file or directory
> make[2]: *** [../upgrade-paths-rules.mk:26: install-upgrade-paths] Error
> 127
> make[1]: *** [Makefile:36: install] Error 1
> make[1]: Leaving directory '/projects/postgis/postgis-git/extensions'
> make: *** [GNUmakefile:27: install] Error 1
New description:
 export PG_VER=17
 export OS_BUILD=64
 cd pg17git
 meson compile
 meson install
 01:31:47
 01:31:47   CPPFLAGS:
 -Upixel -Ubool
 01:31:47
 01:31:47
 01:31:47
 loaded table:
 01:34:49
 01:34:49
 01:34:49
 01:34:49  regress/loader/PointM ........ failed (dumper geog test: dumping
 loaded table:
 01:34:49
 01:34:49
 01:34:56
 On my windows new chain I have configured with meson, autoconf again works
 more or less okay(there are some regress failures but more to do with my
 new chain), however meson build completely falls on its face out of the
 gate and fails to install the extensions.  strk thinks it's something with
 mkdir -p
 /bin/sh
 done
 for DIR in postgis postgis_tiger_geocoder postgis_topology postgis_sfcgal;
 do \
 done
 /bin/sh ../../config/install-sh -c -m 644 "sql/postgis--ANY--3.5.0dev.sql"
 3.5.0dev.sql"
 127
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5764#comment:1>
