[PostGIS] #5764: PostGIS regress issues when building PostgreSQL with meson
trac at osgeo.org
Wed Jul 17 22:09:13 PDT 2024
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.0
Component: install | Version: master
Resolution: | Keywords:
Comment (by robe):
Okay I think I made progress on the debbie front.
Added to the PostGRIS_REGRESS of debbie jenkins job
export PGHOST=localhost
and that seemed to do the trick to get loader regress working.
However install fails with the same issue that winnie is having. I guess
I always test after installing on winnie so assumed the issues were the
same.
01:00:17 ---- Making install in postgis
01:00:17 make[2]: Entering directory
'/var/lib/jenkins/workspace/postgis/branches/3.5/extensions/postgis'
01:00:17 /bin/mkdir -p
'/var/lib/jenkins/workspace/pg/rel/pg17w64/share/postgresql/extension'
01:00:17 mkdir -p
"/var/lib/jenkins/workspace/pg/rel/pg17w64/share/postgresql/extension"
01:00:17 /bin/sh ../../config/install-sh -c -m 644 "sql/postgis--ANY--
3.5.0dev.sql"
"/var/lib/jenkins/workspace/pg/rel/pg17w64/share/postgresql/extension/postgis
--ANY--3.5.0dev.sql"
01:00:17 /bin/sh: 0: cannot open ../../config/install-sh: No such file
01:00:17 make[2]: *** [../upgrade-paths-rules.mk:26: install-upgrade-
paths] Error 2
01:00:17 make[2]: Leaving directory
01:00:17 make[1]: *** [Makefile:36: install] Error 1
01:00:17 make[1]: Leaving directory
'/var/lib/jenkins/workspace/postgis/branches/3.5/extensions'
01:00:17 make: *** [GNUmakefile:27: install] Error 1
01:00:17 Build step 'Execute shell' marked build as failure
01:00:17 [Gitea] do not publish assets due to build being non-Successfully
01:00:17 Triggering a new build of PostgreSQL stop
01:00:17 Finished: FAILURE
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5764#comment:2>
