[SCM] PostGIS branch master updated. 3.4.0rc1-1136-g2773d7419
Sat Jun 1 06:27:57 PDT 2024
the project "PostGIS".
       via  2773d7419c4ada598847e1b5ac9b292cbd409846 (commit)
      from  d107a0b2e95ddc1443399bdb0b84c7ee58f972d8 (commit)
revisions in full, below.
commit 2773d7419c4ada598847e1b5ac9b292cbd409846
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Jun 1 15:27:44 2024 +0200
    Simplify code of winnie build script
diff --git a/ci/winnie/build_postgis.sh b/ci/winnie/build_postgis.sh
index efbcbfefc..f410e720e 100644
--- a/ci/winnie/build_postgis.sh
+++ b/ci/winnie/build_postgis.sh
@@ -52,39 +52,25 @@ if [ -n "$PCRE_VER" ]; then
     export PATH="${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
 fi
+export LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${LZ4_PATH}/bin -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib"
 if [$INCLUDE_MINOR_LIB == "1"]; then
+  EXTRA_CONFIGURE_ARGS="${EXTRA_CONFIGURE_ARGS} --with-library-minor-version"
+fi
-#CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include" \
-#CFLAGS="-Wall -fno-omit-frame-pointer"
-#LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib" \
-LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${LZ4_PATH}/bin -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib" \
 ./configure \
-  --host=${MINGHOST} --with-xml2config=${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin/xml2-config  \
-  --with-pgconfig=${PGPATH}/bin/pg_config \
+  --host=${MINGHOST} \
+  --prefix=${PROJECTS}/postgis/liblwgeom-${POSTGIS_VER}w${OS_BUILD}${GCC_TYPE} \
   --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/geos-config \
+  --with-gettext=no \
+  --with-gui \
   --with-libiconv=${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE} \
-  --with-gui --with-gettext=no \
-  --with-sfcgal=${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/sfcgal-config \
-  --prefix=${PROJECTS}/postgis/liblwgeom-${POSTGIS_VER}w${OS_BUILD}${GCC_TYPE} --with-library-minor-version
-  #exit
-else
-./configure \
-  --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/geos-config \
-  --with-libiconv=${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE} \
-fi;
+  --with-xml2config=${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin/xml2-config  \
+  ${EXTRA_CONFIGURE_ARGS}
 make clean
-#patch liblwgeom generated make to get rid of dynamic linking
-#sed -i 's/LDFLAGS += -no-undefined//g' liblwgeom/Makefile
 make
 make install
Summary of changes:
 ci/winnie/build_postgis.sh | 34 ++++++++++------------------------
 1 file changed, 10 insertions(+), 24 deletions(-)
hooks/post-receive
