[SCM] PostGIS branch master updated. 3.4.0rc1-1141-ga1922ae9d
git at osgeo.org
git at osgeo.org
Sun Jun 2 01:40:40 PDT 2024
the project "PostGIS".
via a1922ae9d3d8a00b431c35ef39c6bbc04d4c5fa3 (commit)
via e1785e5bca139fac2be3df309a76c4982e489be1 (commit)
via 3dfa59f318945883a9f94c7dd7e8efe078142a92 (commit)
from 4903c6f76a29750e53d0ad923f9f67a6f4029c02 (commit)
revisions in full, below.
commit a1922ae9d3d8a00b431c35ef39c6bbc04d4c5fa3
Author: Regina Obe <lr at pcorp.us>
Date: Sun Jun 2 04:28:16 2024 -0400
Additional changes to ST_RemoveSmallParts
- Add To NEWS ST_RemoveSmallParts, and cleanup prior NEWS commit
- Move ST_RemoveIrrelevantPointsForView before ST_RemoveSmallParts
- Mark ST_RemoveSmallParts as IMMUTABLE and add costing
- References https://github.com/postgis/postgis/pull/768
- References #5706
diff --git a/NEWS b/NEWS
index ab90a927a..f28a02d90 100644
--- a/NEWS
+++ b/NEWS
@@ -66,8 +66,8 @@ Andreas Schild (German Team)
CG_3DDistance, CG_Distance (Loïc Bartoletti)
- #5687, Don't rely on search_path to determine postgis schema
Fix for PG17 security change (Regina Obe)
- - #5705, GH-767, Remove irrelevant points for view (Sam Peters)
- - #5706, GH-768, Remove small parts (Sam Peters)
+ - #5705, GH-767, Remove irrelevant points for view: ST_RemoveIrrelevantPointsForView (Sam Peters)
+ - #5706, GH-768, Remove small parts: ST_RemoveSmallParts (Sam Peters)
* Enhancements *
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 75134caca..c8f0ed48b 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -6967,17 +6967,6 @@ CREATE OR REPLACE FUNCTION ST_3DLineInterpolatePoint(geometry, float8)
#include "postgis_spgist.sql.in"
#include "postgis_letters.sql"
--- ST_RemoveSmallParts
--- Availability: 3.5.0
-CREATE OR REPLACE FUNCTION ST_RemoveSmallParts(geometry, double precision, double precision)
-RETURNS geometry
-AS 'MODULE_PATHNAME','ST_RemoveSmallParts'
-LANGUAGE 'c' VOLATILE STRICT;
-- ST_RemoveIrrelevantPointsForView
@@ -6988,4 +6977,14 @@ AS 'MODULE_PATHNAME','ST_RemoveIrrelevantPointsForView'
LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
_COST_MEDIUM;
+-- ST_RemoveSmallParts
+-- Availability: 3.5.0
+CREATE OR REPLACE FUNCTION ST_RemoveSmallParts(geometry, double precision, double precision)
+RETURNS geometry
+AS 'MODULE_PATHNAME','ST_RemoveSmallParts'
+LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
+ _COST_MEDIUM;
COMMIT;
commit e1785e5bca139fac2be3df309a76c4982e489be1
Date: Sun Jun 2 04:26:51 2024 -0400
Add Remove small parts feature to news
index da043ec6a..ab90a927a 100644
--- a/NEWS
+++ b/NEWS
@@ -67,6 +67,7 @@ Andreas Schild (German Team)
+ - #5706, GH-768, Remove small parts (Sam Peters)
* Enhancements *
commit 3dfa59f318945883a9f94c7dd7e8efe078142a92
Date: Sun Jun 2 04:24:26 2024 -0400
Remove small parts
- Closes https://github.com/postgis/postgis/pull/768
- Closes #5706
Author: Sam Peters
diff --git a/doc/html/images/static/st_removesmallparts.png b/doc/html/images/static/st_removesmallparts.png
new file mode 100644
index 000000000..2b2a7e06e
Binary files /dev/null and b/doc/html/images/static/st_removesmallparts.png differ
diff --git a/doc/reference_editor.xml b/doc/reference_editor.xml
index b19080547..415c0da1c 100644
--- a/doc/reference_editor.xml
+++ b/doc/reference_editor.xml
@@ -1856,6 +1856,101 @@ SELECT ST_AsText( ST_RemoveRepeatedPoints( 'LINESTRING (0 0, 0 0, 1 1, 5 5, 1 1,
</refentry>
+ <refentry xml:id="ST_RemoveSmallParts">
+ <refnamediv>
+ <refname>ST_RemoveSmallParts</refname>
+ <refpurpose>Removes small parts (polygon rings or linestrings) of a geometry.</refpurpose>
+ </refnamediv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>geometry <function>ST_RemoveSmallParts</function></funcdef>
+ <paramdef><type>geometry </type> <parameter>geom</parameter></paramdef>
+ <paramdef><type>double precision </type> <parameter>minSizeX</parameter></paramdef>
+ <paramdef><type>double precision </type> <parameter>minSizeY</parameter></paramdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <title>Description</title>
+ <para>Returns a <xref linkend="geometry"/> without small parts (exterior or interior polygon rings, or linestrings).</para>
+ <para>This function can be used as preprocessing step for creating simplified maps, e. g. to remove small islands or holes.</para>
+ <para>It evaluates only geometries of type (MULTI)POLYGON and (MULTI)LINESTRING. Other geometries remain unchanged.</para>
+ <para>If <parameter>minSizeX</parameter> is greater than 0, parts are sorted out if their width is smaller than <parameter>minSizeX</parameter>.</para>
+ <para>If <parameter>minSizeY</parameter> is greater than 0, parts are sorted out if their height is smaller than <parameter>minSizeY</parameter>.</para>
+ <para>Both <parameter>minSizeX</parameter> and <parameter>minSizeY</parameter> are measured in coordinate system units of the geometry.</para>
+ <para>For polygon types, evaluation is done separately for each ring which can lead to one of the following results:
+ <itemizedlist>
+ <listitem><para>the original geometry,</para></listitem>
+ <listitem><para>a POLYGON with all rings with less vertices,</para></listitem>
+ <listitem><para>a POLYGON with a reduced number of interior rings (having possibly less vertices),</para></listitem>
+ <listitem><para>a POLYGON EMPTY, or</para></listitem>
+ <listitem><para>a MULTIPOLYGON with a reduced number of polygons (having possibly less interior rings or vertices), or</para></listitem>
+ <listitem><para>a MULTIPOLYGON EMPTY.</para></listitem>
+ </itemizedlist>
+ </para>
+ <para>For linestring types, evaluation is done for each linestring which can lead to one of the following results:
+ <itemizedlist>
+ <listitem><para>a LINESTRING with a reduced number of vertices,</para></listitem>
+ <listitem><para>a LINESTRING EMPTY,</para></listitem>
+ <listitem><para>a MULTILINESTRING with a reduced number of linestrings (having possibly less vertices), or</para></listitem>
+ <listitem><para>a MULTILINESTRING EMPTY.</para></listitem>
+ </itemizedlist>
+ </para>
+ <para>
+ <informalfigure>
+ <mediaobject>
+ <imageobject>
+ <imagedata fileref="images/st_removesmallparts.png"/>
+ </imageobject>
+ <caption>
+ <para>Example: ST_RemoveSmallParts() applied to a multi-polygon. Blue parts remain.</para>
+ </caption>
+ </mediaobject>
+ </informalfigure>
+ </para>
+ <para role="availability" conformance="3.5.0">Availability: 3.5.0</para>
+ </refsection>
+ <refsection>
+ <title>Examples</title>
+ <programlisting>
+ SELECT ST_AsText(
+ ST_RemoveSmallParts(
+ ST_GeomFromText('MULTIPOLYGON(
+ ((60 160, 120 160, 120 220, 60 220, 60 160), (70 170, 70 210, 110 210, 110 170, 70 170)),
+ ((85 75, 155 75, 155 145, 85 145, 85 75)),
+ ((50 110, 70 110, 70 130, 50 130, 50 110)))'),
+ 50, 50));
+ st_astext
+ MULTIPOLYGON(((60 160,120 160,120 220,60 220,60 160)),((85 75,155 75,155 145,85 145,85 75)))
+ </programlisting>
+ <programlisting>
+ SELECT ST_AsText(
+ ST_GeomFromText('LINESTRING(10 10, 20 20)'),
+ 50, 50));
+ st_astext
+ LINESTRING EMPTY
+ </programlisting>
+ </refsection>
+ </refentry>
<refentry xml:id="ST_Reverse">
<refnamediv>
<refname>ST_Reverse</refname>
diff --git a/postgis/Makefile.in b/postgis/Makefile.in
index 780287b1b..15a69d2d4 100644
--- a/postgis/Makefile.in
+++ b/postgis/Makefile.in
@@ -131,6 +131,7 @@ PG_OBJS= \
lwgeom_in_flatgeobuf.o \
lwgeom_out_flatgeobuf.o \
lwgeom_remove_irrelevant_points_for_view.o \
+ lwgeom_remove_small_parts.o \
postgis_legacy.o
# Objects to build using PGXS
diff --git a/postgis/lwgeom_remove_small_parts.c b/postgis/lwgeom_remove_small_parts.c
index 000000000..94192c023
--- /dev/null
+++ b/postgis/lwgeom_remove_small_parts.c
@@ -0,0 +1,235 @@
+ * PostGIS - Spatial Types for PostgreSQL
+ * http://postgis.net
+ * PostGIS is free software: you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License as published by
+ * the Free Software Foundation, either version 2 of the License, or
+ * (at your option) any later version.
+ * PostGIS is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+ * GNU General Public License for more details.
+ * You should have received a copy of the GNU General Public License
+ * along with PostGIS. If not, see <http://www.gnu.org/licenses/>.
+ * Copyright (C) 2024 Sam Peters <gluser1357 at gmx.de>
+#include "postgres.h"
+#include "funcapi.h"
+#include "utils/array.h"
+#include "utils/builtins.h"
+#include "utils/lsyscache.h"
+#include "utils/numeric.h"
+#include "access/htup_details.h"
+#include "liblwgeom.h"
+#include "liblwgeom_internal.h"
+// helper function for polygon and polyline POINTARRAY's
+// which removes small parts given by dx and dy.
+static void ptarray_remove_dim_helper(POINTARRAY *points, double mindx, double mindy) {
+ int r;
+ double xmin = 0, ymin = 0, xmax = 0, ymax = 0;
+ double x, y;
+ POINT4D point;
+ int npoints = points->npoints;
+ for (r=0; r < npoints; r++) {
+ getPoint4d_p(points, r, &point);
+ x = point.x;
+ y = point.y;
+ if (mindx > 0) {
+ if (!r || xmin > x) xmin = x;
+ if (!r || xmax < x) xmax = x;
+ if (mindy > 0) {
+ if (!r || ymin > y) ymin = y;
+ if (!r || ymax < y) ymax = y;
+ if ((mindx > 0 && xmax - xmin < mindx) ||
+ (mindy > 0 && ymax - ymin < mindy)) {
+ // skip part
+ points->npoints = 0;
+// remove small (sub-)geometries being smaller than given dimensions.
+// 2D-(MULTI)POLYGONs and (MULTI)LINESTRINGs are evaluated, others keep untouched.
+PG_FUNCTION_INFO_V1(ST_RemoveSmallParts);
+Datum ST_RemoveSmallParts(PG_FUNCTION_ARGS) {
+ double mindx = 0, mindy = 0;
+ unsigned int i, j, iw, jw;
+ GSERIALIZED *serialized_in;
+ GSERIALIZED *serialized_out;
+ LWGEOM *geom;
+ // geom input check
+ if (PG_GETARG_POINTER(0) == NULL) {
+ PG_RETURN_NULL();
+ serialized_in = (GSERIALIZED *)PG_DETOAST_DATUM_COPY(PG_GETARG_DATUM(0));
+ if (PG_NARGS() == 3) {
+ if (PG_ARGISNULL(1) || PG_ARGISNULL(2)) {
+ // no valid args given, leave untouched
+ PG_RETURN_POINTER(serialized_in);
+ mindx = PG_GETARG_FLOAT8(1);
+ mindy = PG_GETARG_FLOAT8(2);
+ if (mindx <= 0 && mindy <= 0) {
+ // nothing to do
+ // type check (only polygon and line types are supported yet)
+ if (gserialized_get_type(serialized_in) != POLYGONTYPE &&
+ gserialized_get_type(serialized_in) != MULTIPOLYGONTYPE &&
+ gserialized_get_type(serialized_in) != LINETYPE &&
+ gserialized_get_type(serialized_in) != MULTILINETYPE) {
+ // no (multi)polygon or (multi)linetype, leave untouched
+ else {
+ // unknown params, leave untouched
+ // deserialize geom and copy coordinates (no clone_deep)
+ geom = lwgeom_from_gserialized(serialized_in);
+ if (geom->type == LINETYPE) {
+ LWLINE* line = (LWLINE*)geom;
+ ptarray_remove_dim_helper(line->points, mindx, mindy);
+ if (geom->type == MULTILINETYPE) {
+ LWMLINE* mline = (LWMLINE*)geom;
+ iw = 0;
+ for (i=0; i<mline->ngeoms; i++) {
+ LWLINE* line = mline->geoms[i];
+ if (line->points->npoints) {
+ // keep (reduced) line
+ mline->geoms[iw++] = line;
+ else {
+ // discard current line
+ lwfree(line);
+ mline->ngeoms = iw;
+ if (geom->type == POLYGONTYPE) {
+ LWPOLY* polygon = (LWPOLY*)geom;
+ iw = 0;
+ for (i=0; i<polygon->nrings; i++) {
+ ptarray_remove_dim_helper(polygon->rings[i], mindx, mindy);
+ if (polygon->rings[i]->npoints) {
+ // keep (reduced) ring
+ polygon->rings[iw++] = polygon->rings[i];
+ else {
+ if (!i) {
+ // exterior ring too small, free and skip all rings
+ unsigned int k;
+ for (k=0; k<polygon->nrings; k++) {
+ lwfree(polygon->rings[k]);
+ break;
+ else {
+ // free and remove current interior ring
+ lwfree(polygon->rings[i]);
+ polygon->nrings = iw;
+ if (geom->type == MULTIPOLYGONTYPE) {
+ LWMPOLY* mpolygon = (LWMPOLY*)geom;
+ jw = 0;
+ for (j=0; j<mpolygon->ngeoms; j++) {
+ LWPOLY* polygon = mpolygon->geoms[j];
+ iw = 0;
+ else {
+ if (!i) {
+ unsigned int k;
+ break;
+ else {
+ if (iw) {
+ mpolygon->geoms[jw++] = polygon;
+ else {
+ // free and remove polygon from multipolygon
+ lwfree(polygon);
+ mpolygon->ngeoms = jw;
+ // recompute bbox if computed previously (may result in NULL)
+ lwgeom_drop_bbox(geom);
+ lwgeom_add_bbox(geom);
+ serialized_out = gserialized_from_lwgeom(geom, 0);
+ lwgeom_free(geom);
+ PG_FREE_IF_COPY(serialized_in, 0);
+ PG_RETURN_POINTER(serialized_out);
index 67f63c98b..75134caca 100644
@@ -6968,6 +6968,16 @@ CREATE OR REPLACE FUNCTION ST_3DLineInterpolatePoint(geometry, float8)
+RETURNS geometry
+LANGUAGE 'c' VOLATILE STRICT;
diff --git a/regress/core/remove_small_parts.sql b/regress/core/remove_small_parts.sql
index 000000000..3e5474b67
--- /dev/null
+++ b/regress/core/remove_small_parts.sql
@@ -0,0 +1,17 @@
+SELECT 0, ST_AsText(
+ 50, 50));
+SELECT 1, ST_AsText(
+ 50, 50));
+SELECT 2, ST_AsText(
+ ST_GeomFromText('LINESTRING(10 10 10, 20 20 20)'),
+ 50, 50));
diff --git a/regress/core/remove_small_parts_expected b/regress/core/remove_small_parts_expected
index 000000000..f669c483c
--- /dev/null
+++ b/regress/core/remove_small_parts_expected
@@ -0,0 +1,3 @@
+0|MULTIPOLYGON(((60 160,120 160,120 220,60 220,60 160)),((85 75,155 75,155 145,85 145,85 75)))
+1|LINESTRING EMPTY
+2|LINESTRING Z EMPTY
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
index 7182db0c0..d2dfe71a7 100644
--- a/regress/core/tests.mk.in
+++ b/regress/core/tests.mk.in
@@ -96,6 +96,7 @@ TESTS += \
$(top_srcdir)/regress/core/relate \
$(top_srcdir)/regress/core/remove_irrelevant_points_for_view \
$(top_srcdir)/regress/core/remove_repeated_points \
+ $(top_srcdir)/regress/core/remove_small_parts \
$(top_srcdir)/regress/core/removepoint \
$(top_srcdir)/regress/core/reverse \
$(top_srcdir)/regress/core/scroll \
Summary of changes:
NEWS | 3 +-
doc/html/images/static/st_removesmallparts.png | Bin 0 -> 11314 bytes
doc/reference_editor.xml | 95 ++++++++++
postgis/Makefile.in | 1 +
postgis/lwgeom_remove_small_parts.c | 235 +++++++++++++++++++++++++
postgis/postgis.sql.in | 11 +-
regress/core/remove_small_parts.sql | 17 ++
regress/core/remove_small_parts_expected | 3 +
regress/core/tests.mk.in | 1 +
9 files changed, 364 insertions(+), 2 deletions(-)
create mode 100644 doc/html/images/static/st_removesmallparts.png
create mode 100644 postgis/lwgeom_remove_small_parts.c
create mode 100644 regress/core/remove_small_parts.sql
create mode 100644 regress/core/remove_small_parts_expected
hooks/post-receive
