[PostGIS] #5735: ST_TRANSFORM uses Helmert transformation instead of NTV2 grid (SRID's : 3812 <->31370)
trac at osgeo.org
Mon Jun 3 04:47:53 PDT 2024
3812 <->31370)
Reporter: martinvdb | Owner: rouault
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.4.3
Component: postgis | Version: 3.4.x
Resolution: | Keywords: ST_TRANSFORM Belgium NTV2
Comment (by rouault):
@martinvdb Can you post an example (using for example just a point) of the
ST_Transform() invokation you tried, what you got and what you expected as
result?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5735#comment:2>
