[PostGIS] #5720: shp2pgsql no longer renaming system column names xmin, xmax
trac at osgeo.org
Mon Jun 3 11:18:04 PDT 2024
Reporter: turntwo463 | Owner: robe
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.4.3
Component: utils/shp2pgsql | Version: 3.4.x
Resolution: | Keywords: xmin,xmax
Comment (by Paul Ramsey <pramsey@…>):
In [changeset:"5c5a557d791f3d970fde3bec9e064e586a215da6/git" 5c5a557/git]:
{{{#!CommitTicketReference repository="git"
revision="5c5a557d791f3d970fde3bec9e064e586a215da6"
Actually retain mangled special column names, references #5720
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5720#comment:2>
