[SCM] PostGIS branch master updated. 3.4.0rc1-1144-g003e0d349
Mon Jun 3 19:45:32 PDT 2024
the project "PostGIS".
       via  003e0d349741ce98c86e5898a1012b5b21b34b96 (commit)
      from  471644aa62456fed97cb680d19d743ab6c17607d (commit)
revisions in full, below.
commit 003e0d349741ce98c86e5898a1012b5b21b34b96
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date:   Tue Jun 4 01:01:33 2024 +0000
    Translated PostGIS Manual using Weblate (Japanese)
    Currently translated at 100.0% (5707 of 5707 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 22e9b1b27..67474abf5 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -8,8 +8,8 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2024-03-14 17:56+0000\n"
-"PO-Revision-Date: 2024-05-18 22:45+0000\n"
-"Last-Translator: Yoichi Kayama <yoichi.kayama at gmail.com>\n"
+"PO-Revision-Date: 2024-06-04 02:45+0000\n"
+"Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
 "postgis-manual/ja/>\n"
 "Language: ja\n"
@@ -21376,9 +21376,8 @@ msgid ""
 "Longest line across a single geometry. The length of the line is equal to "
 "the Maximum Distance. The endpoints of the line lie on the Minimum Bounding "
 "Circle."
-msgstr ""
-"一つのジオメトリを横切る最長のラインす。ラインの長さは最大距離と同じです。ラ"
-"インの端点は最小境界円上に存在します。"
+msgstr "一つのジオメトリを横切る最長のラインです。ラインの長さは最大距離と同じです。"
+"ラインの端点は最小境界円上に存在します。"
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/ja/postgis-manual.po | 9 ++++-----
 1 file changed, 4 insertions(+), 5 deletions(-)
hooks/post-receive
