[PostGIS] #5740: ST_DistanceSpheroid doesn't return 0 when one geometry contains the other
PostGIS trac at osgeo.org
Tue Jun 11 19:35:09 PDT 2024
  Reporter:  cdestigter  |      Owner:  pramsey
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:  PostGIS 3.4.3
 Component:  postgis     |    Version:  3.4.x
Resolution:              |   Keywords:
Description changed by cdestigter:
Old description:
> The docs say
> > Returns minimum distance in meters between two lon/lat geometries given
> a particular spheroid
> Based on this description it seems that any intersection between the two
> geometries to cause the result to be 0 (the minimum distance between the
> geometries is 0 because they overlap)
> However, perhaps it actually compares the _edges_ of the geometries and
> so if one geometry contains the other you get a positive number:
> #!sql
> -- touching the edge of the polygon, the result is zero
> => select st_distancespheroid('SRID=4326;POLYGON((0 0,0 1,1 1,1 0,0
> 0))'::GEOMETRY, 'SRID=4326;POINT(0 0.5)'::geometry);
> 0
> -- close to the edge, the result is nonzero
> 0))'::GEOMETRY, 'SRID=4326;POINT(0.1 0.5)'::geometry);
> 11131.528045775543
> -- the further you get from the edge, the larger the result
> 0))'::GEOMETRY, 'SRID=4326;POINT(0.5 0.5)'::geometry);
> 55657.640177233385
> Interestingly, `ST_DistanceSphere` gives the expected result:
> => select st_distancesphere('SRID=4326;POLYGON((0 0,0 1,1 1,1 0,0
> 0
New description:
 The docs say
 geometries should cause the result to be 0 (the minimum distance between
 the geometries is 0 because they overlap)
 However, it seems that actually compares the _edges_ of the geometries -
 #!sql
 0
 11131.528045775543
 55657.640177233385
 0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5740#comment:1>
