[PostGIS] #5741: Crash on PostgreSQL backend exit upon libproj22 cleanup
PostGIS trac at osgeo.org
Wed Jun 12 00:17:13 PDT 2024
  Reporter:  strk     |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 3.4.3
 Component:  postgis  |    Version:  3.4.x
Resolution:  invalid  |   Keywords:
Changes (by strk):
 * status:  new => closed
 * resolution:   => invalid
Comment:
 Given there are two libproj versions shown in the stack trace this ticket
 is clearly invalid as it's some sort of packaging bug (there are 2
 versions of the same library dynamically linked in).
 Let's use a separate ticket for the proj compile-time version check
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5741#comment:5>
