[SCM] PostGIS branch master updated. 3.4.0rc1-1150-g23a1dd033
git at osgeo.org
git at osgeo.org
Wed Jun 12 03:34:32 PDT 2024
the project "PostGIS".
via 23a1dd0339b4333787d23e7f2ffd5f6d293bead8 (commit)
from b63abc4f93630f61bad0bc209d994e445db6660a (commit)
revisions in full, below.
commit 23a1dd0339b4333787d23e7f2ffd5f6d293bead8
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Jun 12 12:32:03 2024 +0200
Drop code paths for PROJ version < 6.1.0, which is now required
Rework format of proj version string to follow GEOS approach
References #5742
diff --git a/README.postgis b/README.postgis
index 36e28a4c3..56b7fe8a2 100644
--- a/README.postgis
+++ b/README.postgis
@@ -16,7 +16,7 @@ Directory structure::
./doc PostGIS Documentation
./extensions Support for the PostgreSQL Extensions framework
./extras Various pieces that didn't belong to mainstream
- (package management specfiles, sample WKB parser,
+ (package management specfiles, sample WKB parser,
postgis_tiger_geocoder)
./fuzzers Google fuzz tests for liblwgeom
./liblwgeom LWGEOM geometry library
@@ -57,9 +57,9 @@ For apt-based systems you can run this command to install the below dependencies
protobuf-c-compiler \
xsltproc
-* PROJ4 (Required, Version 6.1 or higher):
+* PROJ (Required, Version 6.1 or higher):
- The PROJ4 catographic projection library is required if you want to use the
+ The PROJ catographic projection library is required if you want to use the
ST_Transform() function to reproject features within the database.
https://proj.org
@@ -150,7 +150,7 @@ and refuse to proceed. You can specify it using the
PostGIS supports pkg-config for most dependencies.
-If PROJ4 has been installed but cannot be found, configure will complain and
+If PROJ has been installed but cannot be found, configure will complain and
refuse to proceed. You can specify an alternative installation directory using
the ``--with-projdir=DIR`` option.
diff --git a/configure.ac b/configure.ac
index 15f821673..8951b174e 100644
--- a/configure.ac
+++ b/configure.ac
@@ -987,11 +987,11 @@ CFLAGS="$CFLAGS_SAVE"
dnl ===========================================================================
-dnl Detect the version of PROJ.4 installed
+dnl Detect the version of PROJ installed
AC_ARG_WITH([projdir],
- [AS_HELP_STRING([--with-projdir=PATH], [specify the PROJ.4 installation directory])],
+ [AS_HELP_STRING([--with-projdir=PATH], [specify the PROJ installation directory])],
[PROJDIR="$withval"], [PROJDIR=""])
if test ! "x$PROJDIR" = "x"; then
@@ -1015,7 +1015,7 @@ elif test ! -z "$PKG_CONFIG"; then
PROJ_CPPFLAGS="$PROJ_CFLAGS"
PROJ_LDFLAGS="$PROJ_LIBS"
- POSTGIS_PROJ_VERSION=`$PKG_CONFIG proj --modversion | $PERL -nle 'print "$1$2" if /(\d+)\.(\d+)\.(\d+)/'`
+ PROJ_VERSION=`$PKG_CONFIG proj --modversion`
PROJ_LDFLAGS="-lproj"
@@ -1054,19 +1054,21 @@ AC_CHECK_HEADER([proj_api.h],
-dnl Return the PROJ.4 version number if not detected by pkg-config
-if test "x$POSTGIS_PROJ_VERSION" = "x"; then
- AC_PROJ_VERSION([POSTGIS_PROJ_VERSION])
+dnl Find the PROJ version number if not detected via pkg-config
+if test "x$PROJ_VERSION" = "x"; then
+ AC_PROJ_VERSION()
fi
-AC_DEFINE_UNQUOTED([POSTGIS_PROJ_VERSION], [$POSTGIS_PROJ_VERSION], [PROJ library version])
-AC_SUBST([POSTGIS_PROJ_VERSION])
CPPFLAGS="$CPPFLAGS_SAVE"
+POSTGIS_PROJ_VERSION=`echo "${PROJ_VERSION}" | $PERL -nle 'printf "%d%02d%02d\n",$1,$2,$3 if /(\d+)\.(\d+)\.(\d+)/'`
dnl Ensure that we are using PROJ >= 6.1.0 (requires pj_set_searchpath)
if test ! "$POSTGIS_PROJ_VERSION" -ge 61; then
AC_MSG_ERROR([PostGIS requires PROJ >= 6.1.0])
fi
+AC_DEFINE_UNQUOTED([POSTGIS_PROJ_VERSION], [$POSTGIS_PROJ_VERSION], [PROJ library version])
+AC_SUBST([POSTGIS_PROJ_VERSION])
AC_SUBST([PROJ_CPPFLAGS])
AC_SUBST([PROJ_LDFLAGS])
@@ -1958,7 +1960,7 @@ fi
AC_MSG_RESULT()
AC_MSG_RESULT([ -------------- Dependencies -------------- ])
AC_MSG_RESULT([ GEOS config: ${GEOS_CONFIG_SRC}])
-AC_MSG_RESULT([ GEOS version: ${GEOS_VERSION}])
+AC_MSG_RESULT([ GEOS version: ${GEOS_VERSION} (${POSTGIS_GEOS_VERSION})])
if test "x$RASTER" = "xraster"; then
AC_MSG_RESULT([ GDAL config: ${GDAL_CONFIG}])
AC_MSG_RESULT([ GDAL version: ${GDAL_FULL_VERSION}])
@@ -1973,7 +1975,7 @@ if test "x$SUPPORT_POSTGRESQL" = "xyes"; then
else
AC_MSG_RESULT([ PostgreSQL support: DISABLED])
fi
-AC_MSG_RESULT([ PROJ4 version: ${POSTGIS_PROJ_VERSION}])
+AC_MSG_RESULT([ PROJ version: ${PROJ_VERSION} (${POSTGIS_PROJ_VERSION})])
AC_MSG_RESULT([ Libxml2 config: ${XML2CONFIG}])
AC_MSG_RESULT([ Libxml2 version: ${POSTGIS_LIBXML2_VERSION}])
AC_MSG_RESULT([ JSON-C support: ${HAVE_JSON}])
diff --git a/libpgcommon/lwgeom_transform.h b/libpgcommon/lwgeom_transform.h
index 51e71de8a..be0ae1978 100644
--- a/libpgcommon/lwgeom_transform.h
+++ b/libpgcommon/lwgeom_transform.h
@@ -56,12 +56,6 @@ typedef struct srs_precision
int precision_m;
} srs_precision;
-#if POSTGIS_PROJ_VERSION < 61
-/* Needs to call postgis_initialize_cache first */
-char *GetProj4String(int32_t srid);
-#endif
/* Prototypes */
PROJSRSCache* GetPROJSRSCache();
int lwproj_lookup(int32_t srid_from, int32_t srid_to, LWPROJ **pj);
diff --git a/macros/ac_proj4_version.m4 b/macros/ac_proj4_version.m4
index 6d7471ca8..0fe751cec 100644
--- a/macros/ac_proj4_version.m4
+++ b/macros/ac_proj4_version.m4
@@ -10,57 +10,40 @@ dnl *
dnl **********************************************************************
dnl
+dnl Extract the PROJ version number from proj.h
+dnl
+dnl Sets PROJ_VERSION
dnl
AC_DEFUN([AC_PROJ_VERSION], [
- AC_CHECK_HEADER([proj.h], [
- dnl Proj >= 6 include and version string
- AC_RUN_IFELSE([
- AC_LANG_PROGRAM([
- #ifdef HAVE_STDINT_H
- #include <stdio.h>
- #endif
- #include "proj.h"
- FILE *fp;
- int vernum;
+ CFLAGS_SAVE="$CFLAGS"
+ LDFLAGS_SAVE="$LDFLAGS"
+ CFLAGS="$PROJ_CPPFLAGS"
+ LDFLAGS="$PROJ_LDLAGS"
- fp = fopen("conftest.out", "w");
- vernum = (100 * PROJ_VERSION_MAJOR) + (10 * PROJ_VERSION_MINOR) + PROJ_VERSION_PATCH;
- fprintf(fp, "%d\n", vernum);
- fclose(fp);
- dnl The program ran successfully, so return the version number in the form MAJORMINOR
- $1=`cat conftest.out | sed 's/\([[0-9]]\)\([[0-9]]\)\([[0-9]]\)/\1\2/'`
- dnl The program failed so return an empty variable
- $1=""
- dnl Proj < 6 include and version string
- AC_RUN_IFELSE(
- [AC_LANG_PROGRAM([
- #endif
- #include "proj_api.h"
- FILE *fp;
- fprintf(fp, "%d\n", PJ_VERSION);
- fclose(fp);
- $1=""
+ AC_MSG_CHECKING([PROJ version via compiled code])
+ AC_RUN_IFELSE([
+ AC_LANG_PROGRAM([
+ #ifdef HAVE_STDINT_H
+ #include <stdio.h>
+ #endif
+ #include "proj.h"
+ FILE *fp;
+ fp = fopen("conftest.out", "w");
+ fprintf(fp, "%d.%d.%d\n", PROJ_VERSION_MAJOR, PROJ_VERSION_MINOR, PROJ_VERSION_PATCH);
+ fclose(fp);
+ dnl The program ran successfully
+ PROJ_VERSION=`cat conftest.out`
+ AC_MSG_ERROR([Could not extract PROJ version via compiled >=6 test])
+ AC_MSG_RESULT($PROJ_VERSION)
+ CFLAGS="$CFLAGS_SAVE"
+ LDFLAGS="$LDFLAGS_SAVE"
diff --git a/postgis/lwgeom_out_marc21.c b/postgis/lwgeom_out_marc21.c
index c04288379..5cbc46f54 100644
--- a/postgis/lwgeom_out_marc21.c
+++ b/postgis/lwgeom_out_marc21.c
@@ -76,22 +76,6 @@ Datum ST_AsMARC21(PG_FUNCTION_ARGS) {
-// if (GetLWPROJ(srid, srid, &lwproj) == LW_FAILURE) {
-// PG_FREE_IF_COPY(gs, 0);
-// lwpgerror("ST_AsMARC21: Failure reading projections from spatial_ref_sys.");
-// PG_RETURN_NULL();
-//#if POSTGIS_PROJ_VERSION < 61
-// is_latlong = pj_is_latlong(lwproj->pj_from);
-//#else
-// is_latlong = lwproj->source_is_latlong;
-//#endif
- //is_latlong = lwproj_is_latlong(lwproj);
if (!lwproj_is_latlong(lwproj)) {
diff --git a/postgis/lwgeom_transform.c b/postgis/lwgeom_transform.c
index 0cd801ccc..43e40de68 100644
--- a/postgis/lwgeom_transform.c
+++ b/postgis/lwgeom_transform.c
@@ -203,16 +203,11 @@ Datum postgis_proj_version(PG_FUNCTION_ARGS)
stringbuffer_t sb;
- stringbuffer_init(&sb);
- stringbuffer_append(&sb, pj_get_release());
-#else
PJ_INFO pji = proj_info();
stringbuffer_append(&sb, pji.version);
-#endif
-#if POSTGIS_PROJ_VERSION >= 71
+#if POSTGIS_PROJ_VERSION >= 70100
stringbuffer_aprintf(&sb,
" NETWORK_ENABLED=%s",
@@ -232,7 +227,6 @@ Datum postgis_proj_version(PG_FUNCTION_ARGS)
PG_RETURN_POINTER(cstring_to_text(stringbuffer_getstring(&sb)));
* Encode feature in KML
@@ -300,8 +294,6 @@ Datum LWGEOM_asKML(PG_FUNCTION_ARGS)
* PROJ database reading functions
-#if POSTGIS_PROJ_VERSION >= 61
struct srs_entry {
text* auth_name;
text* auth_code;
@@ -470,7 +462,7 @@ srs_find_planar(const char *auth_name, const LWGEOM *bounds, struct srs_data *st
params->bbox_valid = true;
params->allow_deprecated = false;
-#if POSTGIS_PROJ_VERSION >= 81
+#if POSTGIS_PROJ_VERSION >= 80100
params->celestial_body_name = "Earth";
#endif
@@ -523,7 +515,6 @@ srs_find_planar(const char *auth_name, const LWGEOM *bounds, struct srs_data *st
proj_crs_info_list_destroy(crs_list_ptr);
proj_get_crs_list_parameters_destroy(params);
-#endif
* Search for srtext and proj4text given auth_name and auth_srid,
@@ -533,9 +524,6 @@ Datum postgis_srs_entry(PG_FUNCTION_ARGS);
PG_FUNCTION_INFO_V1(postgis_srs_entry);
-#if POSTGIS_PROJ_VERSION < 60
- elog(ERROR, "%s is not supported with Proj < 6.0", __func__);
-#else
Datum result;
struct srs_entry entry;
text* auth_name = PG_GETARG_TEXT_P(0);
@@ -557,7 +545,6 @@ Datum postgis_srs_entry(PG_FUNCTION_ARGS)
PG_RETURN_DATUM(srs_tuple_from_entry(&entry, tuple_desc));
else
PG_RETURN_NULL();
-#endif
@@ -565,9 +552,6 @@ Datum postgis_srs_entry_all(PG_FUNCTION_ARGS);
PG_FUNCTION_INFO_V1(postgis_srs_entry_all);
-#else
FuncCallContext *funcctx;
MemoryContext oldcontext;
struct srs_data *state;
@@ -630,7 +614,6 @@ Datum postgis_srs_entry_all(PG_FUNCTION_ARGS)
/* Stop if lookup fails drastically */
SRF_RETURN_DONE(funcctx);
-#endif
@@ -638,9 +621,6 @@ Datum postgis_srs_codes(PG_FUNCTION_ARGS);
PG_FUNCTION_INFO_V1(postgis_srs_codes);
-#else
@@ -689,7 +669,6 @@ Datum postgis_srs_codes(PG_FUNCTION_ARGS)
-#endif
@@ -701,9 +680,6 @@ Datum postgis_srs_search(PG_FUNCTION_ARGS);
PG_FUNCTION_INFO_V1(postgis_srs_search);
-#else
@@ -771,7 +747,6 @@ Datum postgis_srs_search(PG_FUNCTION_ARGS)
-#endif
diff --git a/postgis/postgis_module.c b/postgis/postgis_module.c
index 9e7adb409..5c207d3da 100644
--- a/postgis/postgis_module.c
+++ b/postgis/postgis_module.c
@@ -63,7 +63,7 @@ static void onExecutorStart(QueryDesc *queryDesc, int eflags);
* system instead of letting them default into the
* stderr.
-#if POSTGIS_PROJ_VERSION > 60
+#if POSTGIS_PROJ_VERSION > 60000
#include "proj.h"
static void
@@ -91,7 +91,7 @@ _PG_init(void)
pg_install_lwgeom_handlers();
/* pass proj messages through the pgsql error handler */
proj_log_func(NULL, NULL, pjLogFunction);
#endif
Summary of changes:
README.postgis | 8 ++---
configure.ac | 22 +++++++------
libpgcommon/lwgeom_transform.h | 6 ----
macros/ac_proj4_version.m4 | 75 ++++++++++++++++--------------------------
postgis/lwgeom_out_marc21.c | 16 ---------
postgis/lwgeom_transform.c | 29 ++--------------
postgis/postgis_module.c | 4 +--
7 files changed, 49 insertions(+), 111 deletions(-)
hooks/post-receive
