[PostGIS] #5742: Proved version of PROJ library PostGIS was compiled against
trac at osgeo.org
Wed Jun 12 03:34:36 PDT 2024
Reporter: strk | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 3.5.0
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by Sandro Santilli <strk@…>):
In [changeset:"23a1dd0339b4333787d23e7f2ffd5f6d293bead8/git" 23a1dd0/git]:
{{{#!CommitTicketReference repository="git"
revision="23a1dd0339b4333787d23e7f2ffd5f6d293bead8"
Drop code paths for PROJ version < 6.1.0, which is now required
Rework format of proj version string to follow GEOS approach
References #5742
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5742#comment:1>
