[PostGIS] #5744: ST_RemoveIrrelevantPointsForView() - Make optimizations based on cartesian math optional
trac at osgeo.org
Thu Jun 13 04:36:31 PDT 2024
math optional
Reporter: gluser1357 | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 3.5.0
Component: postgis | Version: master
Resolution: | Keywords:
Description changed by gluser1357:
Old description:
> The latest optimizations of ''ST_RemoveIrrelevantPointsForView()'' (see
> changes in https://github.com/postgis/postgis/pull/767) for reducing the
> resulting point number make use of cartesian math and assume that
> coordinates won't be reprojected after applying
> ''ST_RemoveIrrelevantPointsForView()'' and before rendering.
> This is fine for common use cases where no reprojection is taking place,
> but for other use cases (where coordinates are stored e. g. as lat/lon
> values, get pre-processed with ''ST_RemoveIrrelevantPointsForView()'',
> reprojected and rendered), rendering artifacts might occur. For such use
> cases it would make sense to turn off those optimizations that use
> cartesian math. This can be achieved by using a new flag
> ''cartesian_hint''. By default (if not specified), no optimizations are
> done.
> I'll post a link to an appropriate PR here soon.
New description:
done.
Here the link to the PR that contains the required changes:
https://github.com/postgis/postgis/pull/774
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5744#comment:1>
