[SCM] PostGIS branch master updated. 3.4.0rc1-1156-g0958dff5d
git at osgeo.org
git at osgeo.org
Tue Jun 18 02:31:01 PDT 2024
the project "PostGIS".
via 0958dff5de13b411063ba9c6398157fb79a839f3 (commit)
via 74e0a8f936f1ac72fcbfaef3f7a5fe6048f29c3e (commit)
from 15e18d33e436c8b1cfe127c089b83572ce8e6a60 (commit)
revisions in full, below.
commit 0958dff5de13b411063ba9c6398157fb79a839f3
Author: DeepL <noreply-mt-deepl at weblate.org>
Date: Tue Jun 18 09:24:59 2024 +0000
Translated PostGIS Manual using Weblate (French)
Currently translated at 98.5% (5625 of 5707 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/fr/
diff --git a/doc/po/fr/postgis-manual.po b/doc/po/fr/postgis-manual.po
index fbb08b96b..557b9320b 100644
--- a/doc/po/fr/postgis-manual.po
+++ b/doc/po/fr/postgis-manual.po
@@ -2,13 +2,14 @@
# Automatically generated, 2023.
# Thomas Muguet <thomas.muguet at oslandia.com>, 2024.
+# DeepL <noreply-mt-deepl at weblate.org>, 2024.
msgid ""
msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2024-03-14 17:56+0000\n"
"PO-Revision-Date: 2024-06-18 09:30+0000\n"
-"Last-Translator: Thomas Muguet <thomas.muguet at oslandia.com>\n"
+"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
"Language-Team: French <https://weblate.osgeo.org/projects/postgis/"
"postgis-manual/fr/>\n"
"Language: fr\n"
@@ -12739,6 +12740,9 @@ msgid ""
"represent the linear segments of the supplied geometry, while the "
"<varname>CIRCULARSTRING</varname>s represent the arc segments."
msgstr ""
+"le champ <parameter>geom</parameter> <varname> LINESTRING</varname>s "
+"représente les segments linéaires de la géométrie fournie, tandis que les "
+"<varname>CIRCULARSTRING</varname>s représentent les segments d'arc."
#. Tag: para
#, no-c-format
commit 74e0a8f936f1ac72fcbfaef3f7a5fe6048f29c3e
Author: Thomas Muguet <thomas.muguet at oslandia.com>
Date: Tue Jun 18 09:10:22 2024 +0000
index b3c25443e..fbb08b96b 100644
@@ -1,21 +1,22 @@
# French translations for postgis package.
+# Thomas Muguet <thomas.muguet at oslandia.com>, 2024.
msgid ""
msgstr ""
-"PO-Revision-Date: 2023-11-29 16:23+0000\n"
-"Last-Translator: Vincent Bre <vincent.bre at oslandia.com>\n"
-"Language-Team: French <https://weblate.osgeo.org/projects/postgis/postgis-"
-"manual/fr/>\n"
+"PO-Revision-Date: 2024-06-18 09:30+0000\n"
+"Last-Translator: Thomas Muguet <thomas.muguet at oslandia.com>\n"
+"Language-Team: French <https://weblate.osgeo.org/projects/postgis/"
+"postgis-manual/fr/>\n"
"Language: fr\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
"Plural-Forms: nplurals=2; plural=n > 1;\n"
-"X-Generator: Weblate 5.0\n"
+"X-Generator: Weblate 5.4.3\n"
#. Tag: chapter
#, no-c-format
@@ -5646,6 +5647,8 @@ msgid ""
", <xref linkend=\"AddTopoGeometryColumn\"/>, <xref "
"linkend=\"CreateTopology\"/>, <xref linkend=\"DropTopology\"/>"
msgstr ""
+", <xref linkend=\"AddTopoGeometryColumn\"/>, <xref linkend=\"CreateTopology\""
+"/>, <xref linkend=\"DropTopology\"/>"
#. Tag: refpurpose
#, no-c-format
@@ -5675,6 +5678,9 @@ msgid ""
"linkend=\"TopoGeo_LoadGeometry\"/>, <xref linkend=\"AddNode\"/>, <xref "
"linkend=\"CreateTopology\"/>"
msgstr ""
+", <xref linkend=\"TopoGeo_AddPolygon\"/>, <xref linkend="
+"\"TopoGeo_LoadGeometry\"/>, <xref linkend=\"AddNode\"/>, <xref linkend="
+"\"CreateTopology\"/>"
#. Tag: refpurpose
#, no-c-format
@@ -5716,6 +5722,9 @@ msgid ""
"linkend=\"TopoGeo_LoadGeometry\"/>, <xref linkend=\"AddEdge\"/>, <xref "
msgstr ""
+"\"TopoGeo_LoadGeometry\"/>, <xref linkend=\"AddEdge\"/>, <xref linkend="
#. Tag: refpurpose
#, no-c-format
@@ -5748,12 +5757,17 @@ msgid ""
"linkend=\"TopoGeo_LoadGeometry\"/>, <xref linkend=\"AddFace\"/>, <xref "
msgstr ""
+", <xref linkend=\"TopoGeo_AddLineString\"/>, <xref linkend="
+"\"TopoGeo_LoadGeometry\"/>, <xref linkend=\"AddFace\"/>, <xref linkend="
#. Tag: refpurpose
#, no-c-format
msgid ""
"Load a geometry into an existing topology, snapping and splitting as needed."
msgstr ""
+"Charge une géométrie dans une topologie existante, en effectuant de "
+"l'accrochage et des divisions si nécessaire."
#. Tag: para
#, no-c-format
@@ -5762,6 +5776,10 @@ msgid ""
"existing nodes or edges within given tolerance. Existing edges and faces may "
"be split as a consequence of the load."
msgstr ""
+"Charge une géométrie dans une topologie existante. La géométrie donnée "
+"s'accrochera aux nœuds ou au arêtes existantes dans la limite d'une "
+"tolérance donnée. Les arêtes et les faces existantes peuvent être divisées "
+"suite au chargement."
#. Tag: para
#, no-c-format
@@ -5774,6 +5792,8 @@ msgid ""
", <xref linkend=\"TopoGeo_AddLineString\"/>, <xref "
"linkend=\"TopoGeo_AddPolygon\"/>, <xref linkend=\"CreateTopology\"/>"
msgstr ""
+"\"TopoGeo_AddPolygon\"/>, <xref linkend=\"CreateTopology\"/>"
#. Tag: title
#, no-c-format
@@ -9675,6 +9695,7 @@ msgstr ""
#, no-c-format
msgid "This will only have data if you marked zcta5 to be loaded"
msgstr ""
+"Celle-ci n'aura des données que si vous avez spécifié le chargement de zcta5"
#. Tag: para
#, no-c-format
@@ -10604,7 +10625,7 @@ msgstr "Charlie Savage"
#. Tag: member
#, no-c-format
msgid "Chris Mayo"
-msgstr ""
+msgstr "Chris Mayo"
#. Tag: member
#, no-c-format
@@ -10754,7 +10775,7 @@ msgstr "Jackie Leng"
#. Tag: member
#, no-c-format
msgid "James Addison"
-msgstr ""
+msgstr "James Addison"
#. Tag: member
#, no-c-format
@@ -11199,7 +11220,7 @@ msgstr "Hunter Systems Group"
#. Tag: link
#, no-c-format
msgid "INIA-CSIC"
-msgstr ""
+msgstr "INIA-CSIC"
#. Tag: link
#, no-c-format
@@ -12223,6 +12244,14 @@ msgid ""
"&reference_transaction; &reference_version; &reference_guc; "
"&reference_troubleshooting;"
msgstr ""
+"&reference_type; &reference_management; &reference_constructor; "
+"&reference_accessor; &reference_editor; &reference_validation; "
+"&reference_srs; &reference_input; &reference_output; &reference_operator; "
+"&reference_relationship; &reference_measure; &reference_overlay; "
+"&reference_processing; &reference_coverage; &reference_transformation; "
+"&reference_cluster; &reference_bbox; &reference_lrs; &reference_trajectory; "
+"&reference_transaction; &reference_version; &reference_guc; "
+"&reference_troubleshooting;"
#. Tag: title
#, no-c-format
Summary of changes:
doc/po/fr/postgis-manual.po | 49 +++++++++++++++++++++++++++++++++++++--------
1 file changed, 41 insertions(+), 8 deletions(-)
hooks/post-receive
