[SCM] PostGIS branch master updated. 3.4.0rc1-1160-g9786611b0
Tue Jun 18 02:37:17 PDT 2024
the project "PostGIS".
       via  9786611b046cd78a7c3b29b6f85389fae82cb12c (commit)
       via  2ec11de4068847ea5e64faecdaa0013745ea504c (commit)
      from  c725452b567022a39980ca521f963b2d91dcbe20 (commit)
revisions in full, below.
commit 9786611b046cd78a7c3b29b6f85389fae82cb12c
Author: DeepL <noreply-mt-deepl at weblate.org>
Date:   Tue Jun 18 09:36:39 2024 +0000
    Translated PostGIS Manual using Weblate (French)
    Currently translated at 98.6% (5630 of 5707 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/fr/
diff --git a/doc/po/fr/postgis-manual.po b/doc/po/fr/postgis-manual.po
index ba4f2d9b7..3fbb3b7c6 100644
--- a/doc/po/fr/postgis-manual.po
+++ b/doc/po/fr/postgis-manual.po
@@ -9,7 +9,7 @@ msgstr ""
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2024-03-14 17:56+0000\n"
 "PO-Revision-Date: 2024-06-18 09:37+0000\n"
-"Last-Translator: Thomas Muguet <thomas.muguet at oslandia.com>\n"
+"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
 "Language-Team: French <https://weblate.osgeo.org/projects/postgis/"
 "postgis-manual/fr/>\n"
 "Language: fr\n"
@@ -13203,6 +13203,9 @@ msgid ""
 "starts at 1. Returns NULL if the geometry is not a CompoundCurve or the "
 "index is out of range."
 msgstr ""
+"Renvoie la Nième géométrie de courbe composante d'une CompoundCurve. L'index "
+"commence à 1. Renvoie NULL si la géométrie n'est pas une CompoundCurve ou si "
+"l'index est hors limites."
 #. Tag: refpurpose
 #, no-c-format
commit 2ec11de4068847ea5e64faecdaa0013745ea504c
Author: Thomas Muguet <thomas.muguet at oslandia.com>
Date:   Tue Jun 18 09:35:16 2024 +0000
index fb813140a..ba4f2d9b7 100644
@@ -8,8 +8,8 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
-"PO-Revision-Date: 2024-06-18 09:32+0000\n"
-"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
+"PO-Revision-Date: 2024-06-18 09:37+0000\n"
+"Last-Translator: Thomas Muguet <thomas.muguet at oslandia.com>\n"
 "Language: fr\n"
@@ -13179,6 +13179,8 @@ msgid ""
 "Return the number of component curves in a CompoundCurve, zero for an empty "
 "CompoundCurve, or NULL for a non-CompoundCurve input."
 msgstr ""
+"Renvoie le nombre de courbes composantes d'une CompoundCurve, zéro pour une "
+"CompoundCurve vide, ou NULL pour une entrée qui n'est pas une CompoundCurve."
 #. Tag: para
 #, no-c-format
@@ -13186,11 +13188,13 @@ msgid ""
 ", <xref linkend=\"ST_Dump\"/>, <xref linkend=\"ST_ExteriorRing\"/>, <xref "
 "linkend=\"ST_NumInteriorRings\"/>, <xref linkend=\"ST_NumGeometries\"/>"
 msgstr ""
+", <xref linkend=\"ST_Dump\"/>, <xref linkend=\"ST_ExteriorRing\"/>, <xref "
+"linkend=\"ST_NumInteriorRings\"/>, <xref linkend=\"ST_NumGeometries\"/>"
 #. Tag: refpurpose
 #, no-c-format
 msgid "Returns the Nth component curve geometry of a CompoundCurve."
-msgstr ""
+msgstr "Renvoie la Nième courbe composante d'une CompoundCurve."
 #. Tag: para
 #, no-c-format
@@ -13282,7 +13286,7 @@ msgid ""
 "a single element."
 msgstr ""
 "Cette fonction analyse le type de la géométrie. Renvoie <varname>TRUE</"
-"varname> pour les collections vides ou ne contenant q'un seul élément."
+"varname> pour les collections vides ou ne contenant qu'un seul élément."
 #. Tag: refpurpose
 #, no-c-format
Summary of changes:
 doc/po/fr/postgis-manual.po | 13 ++++++++++---
 1 file changed, 10 insertions(+), 3 deletions(-)
hooks/post-receive
