[SCM] PostGIS branch master updated. 3.4.0rc1-1174-gebb8f6ecc
Tue Jun 18 05:16:36 PDT 2024
the project "PostGIS".
       via  ebb8f6ecc5195e00c3fa7109aaaa9a65753cc30f (commit)
       via  ca8ead62d153a4a6c34efd778f973d7754d5121b (commit)
      from  df921295f1cc0004bd67ef23ac8d283ba8a8fc4e (commit)
revisions in full, below.
commit ebb8f6ecc5195e00c3fa7109aaaa9a65753cc30f
Author: DeepL <noreply-mt-deepl at weblate.org>
Date:   Tue Jun 18 12:15:17 2024 +0000
    Translated PostGIS Manual using Weblate (French)
    Currently translated at 98.8% (5642 of 5707 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/fr/
diff --git a/doc/po/fr/postgis-manual.po b/doc/po/fr/postgis-manual.po
index fa5bae7c9..24e706e5c 100644
--- a/doc/po/fr/postgis-manual.po
+++ b/doc/po/fr/postgis-manual.po
@@ -9,7 +9,7 @@ msgstr ""
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2024-03-14 17:56+0000\n"
 "PO-Revision-Date: 2024-06-18 12:16+0000\n"
-"Last-Translator: Thomas Muguet <thomas.muguet at oslandia.com>\n"
+"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
 "Language-Team: French <https://weblate.osgeo.org/projects/postgis/"
 "postgis-manual/fr/>\n"
 "Language: fr\n"
@@ -40888,6 +40888,10 @@ msgid ""
 "Results will differ from prior versions, but should be closer to user "
 "expectations."
 msgstr ""
+"Modification : 3.5.0 : la logique qui sous-tend la fonction utilise "
+"désormais un test de confinement dans un tampon, plutôt que l'algorithme "
+"ST_MaxDistance. Les résultats seront différents de ceux des versions "
+"précédentes, mais devraient être plus proches des attentes de l'utilisateur."
 #. Tag: para
 #, no-c-format
commit ca8ead62d153a4a6c34efd778f973d7754d5121b
Author: Thomas Muguet <thomas.muguet at oslandia.com>
Date:   Tue Jun 18 12:15:09 2024 +0000
index d7eca0a52..fa5bae7c9 100644
@@ -8,8 +8,8 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
-"PO-Revision-Date: 2024-06-18 12:15+0000\n"
-"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
+"PO-Revision-Date: 2024-06-18 12:16+0000\n"
+"Last-Translator: Thomas Muguet <thomas.muguet at oslandia.com>\n"
 "Language: fr\n"
@@ -40874,11 +40874,11 @@ msgid ""
 "distance is specified in units defined by the spatial reference system of "
 "the geometries."
 msgstr ""
-"Retourne vrai si <code>g2</code> se trouve entièrement à l'intérieur de "
+"Retourne vrai si <code>g2</code> se trouve entièrement à une distance "
 "<code>distance</code> de <code>g1</code>. Visuellement, la condition est "
-"vraie si <code>g2</code> est contenu dans un tampon <code>distance</code> de "
-"<code>g1</code>. La distance est spécifiée en unités définies par le système "
-"de référence spatial des géométries."
+"vraie si <code>g2</code> est contenu dans un tampon de <code>distance</code> "
+"de <code>g1</code>. La distance est spécifiée en unités définies par le "
+"système de référence spatial des géométries."
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/fr/postgis-manual.po | 14 +++++++++-----
 1 file changed, 9 insertions(+), 5 deletions(-)
hooks/post-receive
