[SCM] PostGIS branch master updated. 3.4.0rc1-1185-g61b0d8d10
git at osgeo.org
git at osgeo.org
Tue Jun 18 05:23:45 PDT 2024
the project "PostGIS".
via 61b0d8d10e5b1adc2c31b54d1ca6dff46b125978 (commit)
via 0a493d9313c2723be05fe080e21dd19f990b4e98 (commit)
from 4b852a57b215052a9667ffed3bf2aa295c8723c2 (commit)
revisions in full, below.
commit 61b0d8d10e5b1adc2c31b54d1ca6dff46b125978
Author: DeepL <noreply-mt-deepl at weblate.org>
Date: Tue Jun 18 12:22:26 2024 +0000
Translated PostGIS Manual using Weblate (French)
Currently translated at 99.1% (5659 of 5707 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/fr/
diff --git a/doc/po/fr/postgis-manual.po b/doc/po/fr/postgis-manual.po
index 7a429393f..4d8defe2e 100644
--- a/doc/po/fr/postgis-manual.po
+++ b/doc/po/fr/postgis-manual.po
@@ -9,7 +9,7 @@ msgstr ""
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2024-03-14 17:56+0000\n"
"PO-Revision-Date: 2024-06-18 12:23+0000\n"
-"Last-Translator: Thomas Muguet <thomas.muguet at oslandia.com>\n"
+"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
"Language-Team: French <https://weblate.osgeo.org/projects/postgis/"
"postgis-manual/fr/>\n"
"Language: fr\n"
@@ -41291,12 +41291,13 @@ msgstr "Calcul l'intersection de deux géométries"
#. Tag: para
#, no-c-format
msgid "Computes the intersection of two geometries."
-msgstr ""
+msgstr "Calcule l'intersection de deux géométries."
#. Tag: para
#, no-c-format
msgid "NOTE: this function returns a geometry representing the intersection."
msgstr ""
+"NOTE : cette fonction renvoie une géométrie représentant l'intersection."
#. Tag: para
#, no-c-format
@@ -41315,7 +41316,7 @@ msgstr ""
#. Tag: refpurpose
#, no-c-format
msgid "Tests if two 3D geometries intersect"
-msgstr ""
+msgstr "Teste si deux géométries 3D se croisent"
#. Tag: para
#, no-c-format
commit 0a493d9313c2723be05fe080e21dd19f990b4e98
Author: Thomas Muguet <thomas.muguet at oslandia.com>
Date: Tue Jun 18 12:22:43 2024 +0000
index e20748be5..7a429393f 100644
@@ -8,8 +8,8 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
-"PO-Revision-Date: 2024-06-18 12:22+0000\n"
-"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
+"PO-Revision-Date: 2024-06-18 12:23+0000\n"
+"Last-Translator: Thomas Muguet <thomas.muguet at oslandia.com>\n"
"Language: fr\n"
@@ -41286,7 +41286,7 @@ msgstr "Fonctions de traitement et de relation SFCGAL"
#. Tag: refpurpose
#, no-c-format
msgid "Computes the intersection of two geometries"
-msgstr "Calcul de l'intersection de deux géométries"
+msgstr "Calcul l'intersection de deux géométries"
#. Tag: para
#, no-c-format
@@ -41301,7 +41301,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ", <xref linkend=\"ST_Intersection\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_Intersection\"/>"
#. Tag: para
#, no-c-format
@@ -41309,6 +41309,8 @@ msgid ""
", <xref linkend=\"ST_3DIntersects\"/>, <xref linkend=\"ST_Intersects\"/>, "
"<xref linkend=\"ST_Disjoint\"/>"
msgstr ""
+", <xref linkend=\"ST_3DIntersects\"/>, <xref linkend=\"ST_Intersects\"/>, "
+"<xref linkend=\"ST_Disjoint\"/>"
#. Tag: refpurpose
#, no-c-format
Summary of changes:
doc/po/fr/postgis-manual.po | 13 ++++++++-----
1 file changed, 8 insertions(+), 5 deletions(-)
hooks/post-receive
