[SCM] PostGIS branch master updated. 3.4.0rc1-1191-g4038f7e61
git at osgeo.org
git at osgeo.org
Tue Jun 18 05:25:16 PDT 2024
the project "PostGIS".
via 4038f7e61f616aeb8bbec4f0a1488e0856106689 (commit)
via 7e1da388ecacf1b30ce181829d2e9224f09c3d86 (commit)
from 978becae4b35d8ea74ddab6acfbeca8e8474ab35 (commit)
revisions in full, below.
commit 4038f7e61f616aeb8bbec4f0a1488e0856106689
Author: DeepL <noreply-mt-deepl at weblate.org>
Date: Tue Jun 18 12:24:47 2024 +0000
Translated PostGIS Manual using Weblate (French)
Currently translated at 99.2% (5662 of 5707 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/fr/
diff --git a/doc/po/fr/postgis-manual.po b/doc/po/fr/postgis-manual.po
index 13b1bdbfb..f84c2e1c7 100644
--- a/doc/po/fr/postgis-manual.po
+++ b/doc/po/fr/postgis-manual.po
@@ -9,7 +9,7 @@ msgstr ""
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2024-03-14 17:56+0000\n"
"PO-Revision-Date: 2024-06-18 12:25+0000\n"
-"Last-Translator: Thomas Muguet <thomas.muguet at oslandia.com>\n"
+"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
"Language-Team: French <https://weblate.osgeo.org/projects/postgis/"
"postgis-manual/fr/>\n"
"Language: fr\n"
@@ -41338,6 +41338,9 @@ msgid ""
"Computes the geometric difference between two geometries. The resulting "
"geometry is a set of points that are present in geomA but not in geomB."
msgstr ""
+"Calcule la différence géométrique entre deux géométries. La géométrie "
+"résultante est un ensemble de points présents dans la géométrie A mais pas "
+"dans la géométrie B."
#. Tag: para
#, no-c-format
commit 7e1da388ecacf1b30ce181829d2e9224f09c3d86
Author: Thomas Muguet <thomas.muguet at oslandia.com>
Date: Tue Jun 18 12:24:43 2024 +0000
index f51d7e350..13b1bdbfb 100644
@@ -8,8 +8,8 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
-"PO-Revision-Date: 2024-06-18 12:24+0000\n"
-"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
+"PO-Revision-Date: 2024-06-18 12:25+0000\n"
+"Last-Translator: Thomas Muguet <thomas.muguet at oslandia.com>\n"
"Language: fr\n"
@@ -41330,7 +41330,7 @@ msgstr ""
#. Tag: refpurpose
#, no-c-format
msgid "Computes the geometric difference between two geometries"
-msgstr "Calcul de la différence géométrique entre deux géométries"
+msgstr "Calcul la différence géométrique entre deux géométries"
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/fr/postgis-manual.po | 7 +++++--
1 file changed, 5 insertions(+), 2 deletions(-)
hooks/post-receive
