[SCM] PostGIS branch master updated. 3.4.0rc1-1199-ge402e7640
git at osgeo.org
git at osgeo.org
Tue Jun 18 05:27:26 PDT 2024
the project "PostGIS".
via e402e7640d103dde4d7ddaf986949a60c6d55b7e (commit)
via ce088d3cb53969d39b6611297d9da7e74020bcf4 (commit)
from a03a38f1eacd2c023da829b31f688ab5d2e8c62b (commit)
revisions in full, below.
commit e402e7640d103dde4d7ddaf986949a60c6d55b7e
Author: DeepL <noreply-mt-deepl at weblate.org>
Date: Tue Jun 18 12:26:51 2024 +0000
Translated PostGIS Manual using Weblate (French)
Currently translated at 99.3% (5671 of 5707 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/fr/
diff --git a/doc/po/fr/postgis-manual.po b/doc/po/fr/postgis-manual.po
index bb7e3db58..d79f77b3f 100644
--- a/doc/po/fr/postgis-manual.po
+++ b/doc/po/fr/postgis-manual.po
@@ -9,7 +9,7 @@ msgstr ""
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2024-03-14 17:56+0000\n"
"PO-Revision-Date: 2024-06-18 12:27+0000\n"
-"Last-Translator: Thomas Muguet <thomas.muguet at oslandia.com>\n"
+"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
"Language-Team: French <https://weblate.osgeo.org/projects/postgis/"
"postgis-manual/fr/>\n"
"Language: fr\n"
@@ -41426,7 +41426,7 @@ msgstr "Calcule la distance 3D minimale entre deux géométries"
#. Tag: para
#, no-c-format
msgid "Computes the minimum 3D distance between two geometries."
-msgstr ""
+msgstr "Calcule la distance 3D minimale entre deux géométries."
#. Tag: para
#, no-c-format
@@ -41434,6 +41434,8 @@ msgid ""
"NOTE: this function returns a double precision value representing the 3D "
"distance."
msgstr ""
+"NOTE : cette fonction renvoie une valeur de double précision représentant la "
+"distance 3D."
#. Tag: para
#, no-c-format
commit ce088d3cb53969d39b6611297d9da7e74020bcf4
Author: Thomas Muguet <thomas.muguet at oslandia.com>
Date: Tue Jun 18 12:26:41 2024 +0000
index 0ff8f3c69..bb7e3db58 100644
@@ -8,8 +8,8 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
-"PO-Revision-Date: 2024-06-18 12:26+0000\n"
-"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
+"PO-Revision-Date: 2024-06-18 12:27+0000\n"
+"Last-Translator: Thomas Muguet <thomas.muguet at oslandia.com>\n"
"Language: fr\n"
@@ -41421,7 +41421,7 @@ msgstr ", <xref linkend=\"ST_Distance\"/>"
#. Tag: refpurpose
#, no-c-format
msgid "Computes the minimum 3D distance between two geometries"
-msgstr "Calcul de la distance 3D minimale entre deux géométries"
+msgstr "Calcule la distance 3D minimale entre deux géométries"
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/fr/postgis-manual.po | 8 +++++---
1 file changed, 5 insertions(+), 3 deletions(-)
hooks/post-receive
