[SCM] PostGIS branch master updated. 3.4.0rc1-1229-g44f715325
Tue Jun 18 07:45:37 PDT 2024
the project "PostGIS".
       via  44f71532565df5492a5c0a6e8721c097356eb627 (commit)
      from  8f54941fe00c47e802ca36b628ed41e1c15519e8 (commit)
revisions in full, below.
commit 44f71532565df5492a5c0a6e8721c097356eb627
Author: Thomas Muguet <thomas.muguet at oslandia.com>
Date:   Tue Jun 18 12:53:05 2024 +0000
    Translated PostGIS Manual using Weblate (French)
    Currently translated at 100.0% (5707 of 5707 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/fr/
diff --git a/doc/po/fr/postgis-manual.po b/doc/po/fr/postgis-manual.po
index a4ef1b31e..5d0974457 100644
--- a/doc/po/fr/postgis-manual.po
+++ b/doc/po/fr/postgis-manual.po
@@ -8,8 +8,8 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2024-03-14 17:56+0000\n"
-"PO-Revision-Date: 2024-06-18 12:53+0000\n"
-"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
+"PO-Revision-Date: 2024-06-18 14:45+0000\n"
+"Last-Translator: Thomas Muguet <thomas.muguet at oslandia.com>\n"
 "Language-Team: French <https://weblate.osgeo.org/projects/postgis/"
 "postgis-manual/fr/>\n"
 "Language: fr\n"
@@ -4436,7 +4436,8 @@ msgid ""
 "type: 1:[multi]point, 2:[multi]line, 3:[multi]poly, 4:collection"
 msgstr ""
 "<varname>type</varname> un entier entre 1 et 4 qui définit le type de la "
-"géométrie : 1:[multi]point, 2:[multi]line, 3:[multi]poly, 4:collection"
+"géométrie : 1 : [multi]point, 2 : [multi]line, 3 : [multi]poly, 4 : "
+"collection"
 #. Tag: title
 #, no-c-format
@@ -35179,9 +35180,7 @@ msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Examples: Comparing selecting all touched vs. not all touched"
-msgstr ""
-"Exemples : Comparaison entre la sélection de toutes les personnes touchées "
-"et la sélection de toutes les personnes non touchées"
+msgstr "Exemples : Comparaison entre la sélection des pixels intersectés et non"
 #. Tag: title
 #, no-c-format
@@ -40937,7 +40936,7 @@ msgstr ""
 msgid "Tests if a geometry is entirely inside a distance of another"
 msgstr ""
 "Teste si une géométrie se trouve entièrement à une distance d'une autre "
-"géométrie."
+"géométrie"
 #. Tag: para
 #, no-c-format
@@ -47462,8 +47461,8 @@ msgid ""
 msgstr ""
 "Dans certaines situations, il est souhaitable de corriger automatiquement la "
 "géométrie non valide. Utilisez la fonction <xref linkend=\"ST_MakeValid\"/> "
-"pour ce faire. (<code>ST_MakeValid</code> est un exemple de fonction "
-"spatiale qui <emphasis>doit</emphasis> permettre une entrée non valide!)"
+"pour cela. (<code>ST_MakeValid</code> est un exemple de fonction spatiale "
+"qui <emphasis>doit</emphasis> permettre une entrée non valide !)"
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/fr/postgis-manual.po | 17 ++++++++---------
 1 file changed, 8 insertions(+), 9 deletions(-)
hooks/post-receive
