[PostGIS] #5725: Undocumented st_offsetcurve behaviour change between 3.2 and 3.3
trac at osgeo.org
Thu May 2 08:28:27 PDT 2024
Reporter: | Owner: pramsey
gbartonowenstl |
Type: defect | Status: new
Priority: medium | Milestone: PostGIS GEOS
Component: postgis | Version: 3.3.x
Resolution: | Keywords: offsetcurve, release notes,
| st_offsetcurve, reversing
Changes (by robe):
* milestone: PostGIS 3.3.7 => PostGIS GEOS
Comment:
We generally don't state changes in behavior caused my geos, since the
versions aren't aligned in any way. So you can't simply say as of GEOS
xxx this might change because we have no idea what version of GEOS people
will be running. For example PostGIS 3.2 and 3.3 are both compatible with
GEOS 3.6 and higher and sadly many people are running on 3.6-3.8 and this
change you are talking about came in GEOS 3.12.
I agree though the GEOS NEWs should have highlighted this reqression in
behavior, which it looks like it didn't, so perhaps an unintentional
regression.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5725#comment:2>
