[PostGIS] #5721: change nextvalue for edge_id, node_id and face_id to use the value in default colum value for primary key
PostGIS trac at osgeo.org
Tue May 7 02:24:05 PDT 2024
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  enhancement        |     Status:  closed
  Priority:  medium             |  Milestone:  PostGIS PostgreSQL
 Component:  topology           |    Version:  master
Resolution:  fixed              |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"cb1a9e88e5e12f8bdbaa8ab8b86989d7702be6f8/git" cb1a9e8/git]:
 {{{#!CommitTicketReference repository="git"
 revision="cb1a9e88e5e12f8bdbaa8ab8b86989d7702be6f8"
 Allow use of custom sequences in topology tables
 Closes #5721
 Includes regress test
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5721#comment:1>
