[SCM] PostGIS branch master updated. 3.4.0rc1-1105-gcb1a9e88e
Tue May 7 02:24:02 PDT 2024
the project "PostGIS".
       via  cb1a9e88e5e12f8bdbaa8ab8b86989d7702be6f8 (commit)
      from  fd3a41f8decabff53bad205ce0b84b008e49ab35 (commit)
revisions in full, below.
commit cb1a9e88e5e12f8bdbaa8ab8b86989d7702be6f8
Author: Lars Aksel Opsahl <lop at skogoglandskap.no>
Date:   Sat Apr 20 07:08:33 2024 +0200
    Allow use of custom sequences in topology tables
    Closes #5721
    Includes regress test
diff --git a/NEWS b/NEWS
index 3e97c2452..afe3a39f5 100644
--- a/NEWS
+++ b/NEWS
@@ -44,6 +44,7 @@ Andreas Schild (German Team)
 * New Features *
+  - #5721, Allow sharing sequences between different topologies (Lars Opsahl)
   - #5667, TopoGeo_LoadGeometry (Sandro Santilli)
   - #5055, add explicit <> geometry operator to prevent non-unique
            error with <> and != (Paul Ramsey)
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index b6c5ea8ac..3a3441480 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -2137,8 +2137,14 @@ cb_getNextEdgeId( const LWT_BE_TOPOLOGY* topo )
   LWT_ELEMID edge_id;
   initStringInfo(sql);
-  appendStringInfo(sql, "SELECT nextval('\"%s\".edge_data_edge_id_seq')",
-                   topo->name);
+  appendStringInfo(sql, "SELECT nextval("
+       "SUBSTRING(column_default, "
+       "POSITION('(' IN column_default)+2, "
+       "(POSITION(':' IN column_default)-POSITION('(' IN column_default)-3))"
+       "FROM information_schema.columns "
+       "WHERE table_schema = '%s' AND table_name='edge_data' AND column_name = 'edge_id' \n",
+      topo->name);
   spi_result = SPI_execute(sql->data, false, 0);
   MemoryContextSwitchTo( oldcontext ); /* switch back */
   if ( spi_result != SPI_OK_SELECT )
diff --git a/topology/sql/populate.sql.in b/topology/sql/populate.sql.in
index bd21a513e..a5d94673c 100644
--- a/topology/sql/populate.sql.in
+++ b/topology/sql/populate.sql.in
@@ -93,6 +93,7 @@ DECLARE
 	nodeid int;
 	rec RECORD;
   containing_face int;
+  seq_name_node text;
 BEGIN
 	-- Atopology and apoint are required
@@ -152,10 +153,16 @@ BEGIN
 	-- Get new node id from sequence
-	FOR rec IN EXECUTE 'SELECT nextval(' ||
-		quote_literal(
-			quote_ident(atopology) || '.node_node_id_seq'
+  EXECUTE FORMAT(
+    $fmt$
+    SELECT column_default
+    FROM information_schema.columns
+    WHERE table_schema = %1$L AND table_name='node' AND column_name = 'node_id'
+    $fmt$,
+    atopology
+  ) INTO seq_name_node;
+	FOR rec IN EXECUTE 'SELECT ' || seq_name_node
 	LOOP
 		nodeid = rec.nextval;
 	END LOOP;
@@ -205,6 +212,7 @@ DECLARE
 	edgeid int;
 	rec RECORD;
   ix geometry;
+  seq_name_edge_data text;
 BEGIN
@@ -333,11 +341,16 @@ BEGIN
 	-- Get new edge id from sequence
-		quote_literal(
-			quote_ident(atopology) || '.edge_data_edge_id_seq'
-	LOOP
+  EXECUTE FORMAT(
+    $fmt$
+    WHERE table_schema = %1$L AND table_name='edge_data' AND column_name = 'edge_id'
+    $fmt$,
+    atopology
+  ) INTO seq_name_edge_data;
+  FOR rec IN EXECUTE 'SELECT ' || seq_name_edge_data	LOOP
 		edgeid = rec.nextval;
 	END LOOP;
@@ -446,6 +459,7 @@ DECLARE
   loc float8;
   segnum int;
   numsegs int;
+  seq_name_face text;
 BEGIN
   -- Atopology and apoly are required
@@ -605,10 +619,16 @@ BEGIN
   -- Get new face id from sequence
-    quote_literal(
-      quote_ident(atopology) || '.face_face_id_seq'
+  EXECUTE FORMAT(
+    $fmt$
+    WHERE table_schema = %1$L AND table_name='face' AND column_name = 'face_id'
+    $fmt$,
+    atopology
+  ) INTO seq_name_face;
+  FOR rec IN EXECUTE 'SELECT ' || seq_name_face
   LOOP
     faceid = rec.nextval;
   END LOOP;
diff --git a/topology/test/regress/share_sequences.sql b/topology/test/regress/share_sequences.sql
new file mode 100644
index 000000000..c90080f62
--- /dev/null
+++ b/topology/test/regress/share_sequences.sql
@@ -0,0 +1,38 @@
+BEGIN;
+set client_min_messages to ERROR;
+SELECT topology.CreateTopology('Main',4326) > 0; -- Create the master topology
+SELECT topology.st_createtopogeo('Main','SRID=4326;POLYGON((0 0, 10 0, 10 10, 0 10, 0 0),(5 5, 8 9, 4 2, 5 5))');
+SELECT max(edge_id)||' max edge_id Main.edge_data' from "Main".edge_data;
+SELECT max(node_id)||' max node_id Main.node' from "Main".node;
+SELECT max(face_id)||' max node_id Main.face' from "Main".face;
+SELECT topology.CreateTopology('temp01',4326) > 0; -- Create temp01 toplogies to use the masters primary keys
+ALTER TABLE temp01.edge_data ALTER COLUMN edge_id set default nextval('"Main".edge_data_edge_id_seq'::regclass);
+ALTER TABLE temp01.node ALTER COLUMN node_id set default nextval('"Main".node_node_id_seq'::regclass);
+ALTER TABLE temp01.face ALTER COLUMN face_id set default nextval('"Main".face_face_id_seq'::regclass);
+DROP SEQUENCE temp01.edge_data_edge_id_seq; -- Drop sequences since we do no need them any more since we now use the main
+DROP SEQUENCE temp01.node_node_id_seq;
+DROP SEQUENCE temp01.face_face_id_seq;
+SELECT topology.CreateTopology('temp02',4326) > 0; -- Create temp02 toplogies to use the masters primary keys
+ALTER TABLE temp02.edge_data ALTER COLUMN edge_id set default nextval('"Main".edge_data_edge_id_seq'::regclass);
+ALTER TABLE temp02.node ALTER COLUMN node_id set default nextval('"Main".node_node_id_seq'::regclass);
+ALTER TABLE temp02.face ALTER COLUMN face_id set default nextval('"Main".face_face_id_seq'::regclass);
+DROP SEQUENCE temp02.edge_data_edge_id_seq; -- Drop sequences since we do no need them any more since we now use the main
+DROP SEQUENCE temp02.node_node_id_seq;
+DROP SEQUENCE temp02.face_face_id_seq;
+SELECT topology.st_createtopogeo('temp01', 'SRID=4326;POLYGON((0 0, 10 0, 10 10, 0 10, 0 0),(5 5, 8 9, 4 2, 5 5))'); -- Add to temp01 id will start on 1
+SELECT max(edge_id)||' max edge_id temp01.edge_data' from temp01.edge_data;
+SELECT max(node_id)||' max node_id temp01.node' from temp01.node;
+SELECT max(face_id)||' max face_id temp01.face' from temp01.face;
+SELECT topology.addEdge('temp02', 'LINESTRING(8 10, 10 10, 10 12, 8 10)'); -- Add to temp01 id will not start on 1
+SELECT max(edge_id)||' max edge_id temp02.edge_data' from temp02.edge_data;
+SELECT max(node_id)||' max node_id temp02.node' from temp02.node;
+SELECT max(face_id)||' max face_id temp02.face' from temp02.face;
+ROLLBACK;
diff --git a/topology/test/regress/share_sequences_expected b/topology/test/regress/share_sequences_expected
index 000000000..b94d73c85
--- /dev/null
+++ b/topology/test/regress/share_sequences_expected
@@ -0,0 +1,15 @@
+t
+Topology Main populated
+2 max edge_id Main.edge_data
+2 max node_id Main.node
+2 max node_id Main.face
+t
+t
+Topology temp01 populated
+4 max edge_id temp01.edge_data
+4 max node_id temp01.node
+4 max face_id temp01.face
+5
+5 max edge_id temp02.edge_data
+5 max node_id temp02.node
+0 max face_id temp02.face
diff --git a/topology/test/tests.mk b/topology/test/tests.mk
index cc4b2b4b2..cbe263369 100644
--- a/topology/test/tests.mk
+++ b/topology/test/tests.mk
@@ -48,8 +48,9 @@ TESTS += \
 	$(top_srcdir)/topology/test/regress/polygonize.sql \
 	$(top_srcdir)/topology/test/regress/populate_topology_layer.sql \
 	$(top_srcdir)/topology/test/regress/removeunusedprimitives.sql \
-	$(top_srcdir)/topology/test/regress/renametopology.sql \
 	$(top_srcdir)/topology/test/regress/renametopogeometrycolumn.sql \
+	$(top_srcdir)/topology/test/regress/renametopology.sql \
+	$(top_srcdir)/topology/test/regress/share_sequences.sql \
 	$(top_srcdir)/topology/test/regress/sqlmm.sql \
 	$(top_srcdir)/topology/test/regress/st_addedgemodface.sql \
 	$(top_srcdir)/topology/test/regress/st_addedgenewfaces.sql \
@@ -71,11 +72,12 @@ TESTS += \
 	$(top_srcdir)/topology/test/regress/st_simplify.sql \
 	$(top_srcdir)/topology/test/regress/topo2.5d.sql \
 	$(top_srcdir)/topology/test/regress/topoelementarray_agg.sql \
+	$(top_srcdir)/topology/test/regress/topoelement_cast.sql \
 	$(top_srcdir)/topology/test/regress/topoelement.sql \
-	$(top_srcdir)/topology/test/regress/topogeo_addlinestring.sql \
 	$(top_srcdir)/topology/test/regress/topogeo_addlinestring_robust.sql \
-	$(top_srcdir)/topology/test/regress/topogeo_addpoint.sql \
+	$(top_srcdir)/topology/test/regress/topogeo_addlinestring.sql \
 	$(top_srcdir)/topology/test/regress/topogeo_addpoint_merge_edges.sql \
+	$(top_srcdir)/topology/test/regress/topogeo_addpoint.sql \
 	$(top_srcdir)/topology/test/regress/topogeo_addpolygon.sql \
 	$(top_srcdir)/topology/test/regress/topogeo_loadgeometry.sql \
 	$(top_srcdir)/topology/test/regress/topogeom_addtopogeom.sql \
@@ -85,6 +87,5 @@ TESTS += \
 	$(top_srcdir)/topology/test/regress/topojson.sql \
 	$(top_srcdir)/topology/test/regress/topologysummary.sql \
 	$(top_srcdir)/topology/test/regress/totopogeom.sql \
-	$(top_srcdir)/topology/test/regress/validatetopology.sql \
 	$(top_srcdir)/topology/test/regress/validatetopologyrelation.sql \
-	$(top_srcdir)/topology/test/regress/topoelement_cast.sql
+	$(top_srcdir)/topology/test/regress/validatetopology.sql
Summary of changes:
 NEWS                                           |  1 +
 topology/postgis_topology.c                    | 10 ++++--
 topology/sql/populate.sql.in                   | 46 ++++++++++++++++++--------
 topology/test/regress/share_sequences.sql      | 38 +++++++++++++++++++++
 topology/test/regress/share_sequences_expected | 15 +++++++++
 topology/test/tests.mk                         | 11 +++---
 6 files changed, 101 insertions(+), 20 deletions(-)
 create mode 100644 topology/test/regress/share_sequences.sql
 create mode 100644 topology/test/regress/share_sequences_expected
hooks/post-receive
