[PostGIS] #5726: Cases where ST_Overlaps(ST_Difference(a, b), b) = TRUE
trac at osgeo.org
Wed May 8 10:38:37 PDT 2024
#5726: Cases where ST_Overlaps(ST_Difference(a,b),b) = TRUE
Reporter: dannytoone | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.4.3
Component: postgis | Version: 3.4.x
Resolution: | Keywords:
Comment (by mdavis):
This can be due to these things:
- (most likely) The results of overlay operations (such a difference) are
subject to numerical rounding, which means that the results might not
exactly match the input linework. This can cause spatial predicates to be
inconsistent with expected results
- (very rare) a bug in the overlay algorithm sometimes causes outputs to
be very different from what is expected. This would show up as a large
difference in area from the expected value.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5726#comment:1>
