[PostGIS] #5727: Winnie Failing on topology_addline and topology_addlinerobust
trac at osgeo.org
Mon May 13 09:11:24 PDT 2024
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.5.0
Component: topology | Version: master
Keywords: |
Winnie has been failing since April 30th. I thought it was GEOS so I
rebuilt geos 3.13, but still failures.
Running after-create script ./regress/hooks/hook-after-create.sql
Executor slow factor: 13.4561 (134.561 ms to fetch full version)
PostgreSQL 15.6, compiled by Visual C++ build 1937, 64-bit
Postgis 3.5.0dev - (3.4.0rc1-1105-gcb1a9e88e) - 2024-05-07 18:58:15
scripts 3.5.0dev 3.4.0rc1-1105-gcb1a9e88e
raster scripts 3.5.0dev 3.4.0rc1-1105-gcb1a9e88e
GEOS: 3.13.0dev-CAPI-1.18.0
./topology/test/regress/topogeo_addlinestring_robust .. failed (diff
expected obtained:
/projects/postgis/tmp/3.5.0dev_pg15_geos3.13_gdal3.8.5w64/test_230_diff)
--- ./topology/test/regress/topogeo_addlinestring_robust_expected
2024-04-30 15:13:51.265763100 -0400
+++ /projects/postgis/tmp/3.5.0dev_pg15_geos3.13_gdal3.8.5w64/test_230_out
2024-05-07 15:42:44.018142100 -0400
@@ -1,2 +1,4 @@
#5699|-checking-
+#5699|addline exception|Spatial exception - geometry intersects edge 3
(XX000)
#5711|-checking-
+#5711|addline exception|Spatial exception - geometry intersects edge 3
(XX000)
./topology/test/regress/topogeo_addlinestring .. failed (diff expected
obtained:
/projects/postgis/tmp/3.5.0dev_pg15_geos3.13_gdal3.8.5w64/test_231_diff)
--- ./topology/test/regress/topogeo_addlinestring_expected 2024-04-30
15:13:51.239393800 -0400
+++ /projects/postgis/tmp/3.5.0dev_pg15_geos3.13_gdal3.8.5w64/test_231_out
2024-05-07 15:42:51.331226400 -0400
@@ -171,8 +171,7 @@
t3280.start|t
t3280|L11
t3280|L22
-t3280|L1b1
-t3280|L1b2
+ERROR: Spatial exception - geometry intersects edge 2
t3280.end|Topology 'bug3280' dropped
t3380.start|t
t3380.L1|1
./topology/test/regress/topogeo_addpoint_merge_edges .. ok in 14071 ms
I'm going to test by downgrading testing to GEOS 3.12 to see if that
resolves the issue
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5727>
