[PostGIS] #5727: Winnie Failing on topology_addline and topology_addlinerobust
trac at osgeo.org
Mon May 13 09:24:18 PDT 2024
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.5.0
Component: topology | Version: master
Resolution: | Keywords: robustness, testsuite, ci
Changes (by strk):
* keywords: => robustness, testsuite, ci
Comment:
Robustness tests are very fragile. I remember we had at some point to pass
-ffloat-store compier switch to make results more stable, is this
something done on the Windows build ?
This is only happening on Windows, as far as we can tell ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5727#comment:1>
