[PostGIS] #5728: berrie (32 bit) crashing on topology topogeo_addpoint_merge_edges
PostGIS trac at osgeo.org
Mon May 13 09:34:57 PDT 2024
 Reporter:  robe      |      Owner:  strk
     Type:  defect    |     Status:  new
 Priority:  blocker   |  Milestone:  PostGIS 3.5.0
Component:  topology  |    Version:  3.4.x
 Keywords:            |
 02:22:42  topology/test/regress/topogeo_addpoint_merge_edges ..Died at
 ./regress/run_test.pl line 979.
 02:22:48  failed (psql exited with an error: /tmp/pgis_reg/test_222_out)
 02:22:48
 02:22:48 sn.CW-back-merge|-checking-
 02:22:48 sn.CW-back-merge.ep-edges|-checking-
 02:22:48 sn.CW-back-merge.ep-edges-back|-checking-
 02:22:48 sn.CCW-back-merge|-checking-
 02:22:48 sn.CCW-back-merge.ep-edges|-checking-
 02:22:48 sn.CCW-back-merge.ep-edges-back|-checking-
 02:22:48 sn.CW-forw-merge|-checking-
 02:22:48 sn.CW-forw-merge.ep-edges|-checking-
 02:22:48 sn.CW-forw-merge.ep-edges-back|-checking-
 02:22:48 sn.CCW-forw-merge|-checking-
 02:22:48 sn.CCW-forw-merge.ep-edges|-checking-
 02:22:48 sn.CCW-forw-merge.ep-edges-back|-checking-
 02:22:48 en.CW-back-merge|-checking-
 02:22:48 en.CW-back-merge.ep-edges|-checking-
 02:22:48 en.CW-back-merge.ep-edges-back|-checking-
 02:22:48 en.CW-forw-merge|-checking-
 02:22:48 en.CW-forw-merge.ep-edges|-checking-
 02:22:48 en.CW-forw-merge.ep-edges-back|-checking-
 02:22:48 psql:topogeo_addpoint_merge_edges.sql:320: server closed the
 connection unexpectedly
 02:22:48        This probably means the server terminated abnormally
 02:22:48        before or while processing the request.
 02:22:48 psql:topogeo_addpoint_merge_edges.sql:320: error: connection to
 server was lost
 This particular one looks like it might have started on the May 6th, but
 hard to tell since berrie has been failing for a while on garden tests
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5728>
