[PostGIS] #5728: berrie (32 bit) crashing on topology topogeo_addpoint_merge_edges
PostGIS trac at osgeo.org
Thu May 16 00:57:59 PDT 2024
  Reporter:  robe      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  blocker   |  Milestone:  PostGIS 3.5.0
 Component:  topology  |    Version:  3.4.x
Resolution:            |   Keywords:
Old description:
> 02:22:42  topology/test/regress/topogeo_addpoint_merge_edges ..Died at
> ./regress/run_test.pl line 979.
> 02:22:48  failed (psql exited with an error: /tmp/pgis_reg/test_222_out)
> 02:22:48
> 02:22:48 sn.CW-back-merge|-checking-
> 02:22:48 sn.CW-back-merge.ep-edges|-checking-
> 02:22:48 sn.CW-back-merge.ep-edges-back|-checking-
> 02:22:48 sn.CCW-back-merge|-checking-
> 02:22:48 sn.CCW-back-merge.ep-edges|-checking-
> 02:22:48 sn.CCW-back-merge.ep-edges-back|-checking-
> 02:22:48 sn.CW-forw-merge|-checking-
> 02:22:48 sn.CW-forw-merge.ep-edges|-checking-
> 02:22:48 sn.CW-forw-merge.ep-edges-back|-checking-
> 02:22:48 sn.CCW-forw-merge|-checking-
> 02:22:48 sn.CCW-forw-merge.ep-edges|-checking-
> 02:22:48 sn.CCW-forw-merge.ep-edges-back|-checking-
> 02:22:48 en.CW-back-merge|-checking-
> 02:22:48 en.CW-back-merge.ep-edges|-checking-
> 02:22:48 en.CW-back-merge.ep-edges-back|-checking-
> 02:22:48 en.CW-forw-merge|-checking-
> 02:22:48 en.CW-forw-merge.ep-edges|-checking-
> 02:22:48 en.CW-forw-merge.ep-edges-back|-checking-
> 02:22:48 psql:topogeo_addpoint_merge_edges.sql:320: server closed the
> connection unexpectedly
> 02:22:48        This probably means the server terminated abnormally
> 02:22:48        before or while processing the request.
> 02:22:48 psql:topogeo_addpoint_merge_edges.sql:320: error: connection to
> server was lost
> This particular one looks like it might have started on the May 6th, but
> hard to tell since berrie has been failing for a while on garden tests
New description:
 02:22:48
 server was lost
Comment (by strk):
 I know I'm not properly doing memory management with the new function, can
 that be the cause ? Is there a way for me to ssh into berrie and build
 manually ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5728#comment:1>
