[PostGIS] #5728: 32bit builds crashing on topology topogeo_addpoint_merge_edges (was: berrie (32 bit) crashing on topology topogeo_addpoint_merge_edges)
PostGIS trac at osgeo.org
Thu May 16 07:39:10 PDT 2024
  Reporter:  robe      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  blocker   |  Milestone:  PostGIS 3.5.0
 Component:  topology  |    Version:  master
Resolution:            |   Keywords:
Changes (by strk):
 * version:  3.4.x => master
 * summary:  berrie (32 bit) crashing on topology
     topogeo_addpoint_merge_edges => 32bit builds crashing on topology
Comment:
 Also bessie crashes, see
 https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie32/5900/console
 And gitlab too, once it gets a chance to run (currently not getting there
 due to #5724): https://gitlab.com/strk/postgis/-/jobs/6870457656
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5728#comment:2>
