[PostGIS] #5728: 32bit builds crashing on topology topogeo_addpoint_merge_edges
trac at osgeo.org
Thu May 16 08:53:40 PDT 2024
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.5.0
Component: topology | Version: master
Resolution: | Keywords:
Comment (by strk):
I'm running on bessie32. This seems to be the culprit:
SELECT * FROM runTest('snap-CW-newface-sp',
ARRAY[
'LINESTRING(0 1, 100 1)',
'LINESTRING(0 -10,50 0,100 -10)',
'LINESTRING(0 1, 0 -10)'
], 'POINT(50 0)', 2
Debug output:
DEBUG: [topo/lwgeom_topo.c:_lwt_FirstDistinctVertex2D:1450] first point
is index 1
DEBUG: [topo/lwgeom_topo.c:_lwt_FirstDistinctVertex2D:1454] testing point
0
DEBUG: [topo/lwgeom_topo.c:_lwt_FindAdjacentEdges:1665] edge 3 ends on
node 6, edgeend is [50 0,0 -10]
DEBUG: [topo/lwgeom_topo.c:_lwt_FindAdjacentEdges:1677] azimuth of edge
3: 4.51499342053481 (diff: 2.96419442771306)
DEBUG: [topo/lwgeom_topo.c:_lwt_FindAdjacentEdges:1706] new nextCCW edge
is 3, outgoing, from start point, with face_left 1 and face_right 1
(previous had maxaz=0.217393, face_left is new ccwFace)
DEBUG: [topo/lwgeom_topo.c:_lwt_FindAdjacentEdges:1721] edges adjacent to
azimuth 1.5508 (incident to node 6): CW:5(0.217393) CCW:-3(2.96419)
DEBUG: [topo/lwgeom_topo.c:_lwt_SnapEdgeToExistingNode:5231] Component 1
of split edge 0 next CW is 2, next CCW is 0
server closed the connection unexpectedly
This probably means the server terminated abnormally
before or while processing the request.
The connection to the server was lost. Attempting reset: Failed.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5728#comment:3>
