[PostGIS] #5729: topology failing on building on GHA that treat warnins as errors and Cirrus FreeBSD
trac at osgeo.org
Wed May 15 11:50:56 PDT 2024
FreeBSD
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.5.0
Component: topology | Version: master
Keywords: |
Now that I have GHA properly showing failures, it's showing a bit of a
train wreck on topology.
The ubuntu tests that treat warnings as errors:
https://github.com/postgis/postgis/actions/runs/9066395839/job/24909205720
local/include -c lwcurvepoly.c -o lwcurvepoly.o >/dev/null 2>&1
topo/lwgeom_topo.c:5136:19: error: comparison of integer expressions of
different signedness: 'int' and 'uint64_t' {aka 'long unsigned int'}
[-Werror=sign-compare]
5136 | for ( int t=0; t<firstNodeEdges->numEdges; t++ )
topo/lwgeom_topo.c:5240:23: error: comparison of integer expressions of
5240 | for ( int t=0; t<splitNodeEdges->numEdges; t++ )
topo/lwgeom_topo.c:5459:23: error: comparison of integer expressions of
5459 | for ( int t=0; t<commonNodeEdges->numEdges; t++ )
libtool: compile: gcc -I./../deps/ryu/.. -I/usr/local/include
-I/usr/include/libxml2 -I/usr/local/include -I/usr/include/json-c -DNDEBUG
-I. -I. -std=gnu99 -g -O2 -mtune=generic -fno-omit-frame-pointer -Werror
-Wall -Wextra -Wformat -Werror=format-security -Wno-unused-parameter -Wno-
implicit-fallthrough -Wno-cast-function-type -fno-math-errno -fno-signed-
zeros -Wall -O2 -fPIC -DPIC -I/usr/local/include -c gserialized.c -o
gserialized.o >/dev/null 2>&1
topo/lwgeom_topo.c:5792:21: error: comparison of integer expressions of
5792 | for ( int t=0; t<splitNodeEdges->numEdges; t++ )
topo/lwgeom_topo.c:5920:21: error: comparison of integer expressions of
5920 | for ( int t=0; t<lastNodeEdges->numEdges; t++ )
topo/lwgeom_topo.c:6053:10: error: absolute value function 'abs' given an
argument of type 'LWT_ELEMID' {aka 'long int'} but has parameter of type
'int' which may cause truncation of value [-Werror=absolute-value]
6053 | if ( abs(edge->next_right) == replacedBy[0] ) {
topo/lwgeom_topo.c:6070:21: error: comparison of integer expressions of
6070 | for ( int t=0; t<firstNodeEdges->numEdges; t++ )
zeros -Wall -O2 -fPIC -DPIC -I/usr/local/include -c lwpoly.c -o lwpoly.o
>/dev/null 2>&1
topo/lwgeom_topo.c:6122:21: error: comparison of integer expressions of
6122 | for ( int t=0; t<lastNodeEdges->numEdges; t++ )
cc1: all warnings being treated as errors
make[1]: *** [Makefile:230: topo/lwt_edgeend_star.lo] Error 1
On Cirrhus FreeBSD 13 (but oddly bessie (64-bit) is showing no errors
bessie32 as mentioned in another ticket is crashing, but gets past the
compile phase
argument of type 'LWT_ELEMID' (aka 'long') but has parameter of type 'int'
which may cause truncation of value [-Werror,-Wabsolute-value]
topo/lwgeom_topo.c:6053:10: note: use function 'labs' instead
labs
1 error generated.
gmake[1]: *** [Makefile:230: topo/lwgeom_topo.lo] Error 1
gmake[1]: Leaving directory '/tmp/cirrus-ci-build/liblwgeom'
gmake: *** [GNUmakefile:27: all] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5729>
