[PostGIS] #5729: topology failing on building on GHA that treat warnins as errors and Cirrus FreeBSD
PostGIS trac at osgeo.org
Thu May 16 00:56:51 PDT 2024
FreeBSD
  Reporter:  robe      |      Owner:  strk
      Type:  defect    |     Status:  closed
  Priority:  blocker   |  Milestone:  PostGIS 3.5.0
 Component:  topology  |    Version:  master
Resolution:  fixed     |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"d64abc400afd5d3eb2dd58de7e4fcbdd8cc3326e/git" d64abc4/git]:
 {{{#!CommitTicketReference repository="git"
 revision="d64abc400afd5d3eb2dd58de7e4fcbdd8cc3326e"
 Fix compiler warnings about signed/unsigned comparisons and abs() use
 Closes #5729
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5729#comment:1>
