[SCM] PostGIS branch master updated. 3.4.0rc1-1118-g2df90f2a4
git at osgeo.org
git at osgeo.org
Mon May 20 10:28:20 PDT 2024
the project "PostGIS".
via 2df90f2a4f450c21183edd830b89bbe29926472e (commit)
from 1cfeb88f9a4786ded15db1f4ede6821f3184316e (commit)
revisions in full, below.
commit 2df90f2a4f450c21183edd830b89bbe29926472e
Author: Sandro Santilli <strk at kbt.io>
Date: Mon May 20 19:27:15 2024 +0200
Show last lines of garden logs on failure, pre-drop the gardendb
References #5636
diff --git a/regress/Makefile.in b/regress/Makefile.in
index 070f1388a..8f5472c1b 100644
--- a/regress/Makefile.in
+++ b/regress/Makefile.in
@@ -100,16 +100,24 @@ staged-install:
$(PERL) -pi -e 's,\$$libdir,$(REGRESS_INSTALLDIR)/lib,g' $(REGRESS_INSTALLDIR)/share/contrib/postgis/*.sql
garden: staged-install
+ dropdb --if-exists $(GARDENDB)
createdb $(GARDENDB)
psql -qX -v ON_ERROR_STOP=true -d $(GARDENDB) < $(REGRESS_INSTALLDIR)/share/contrib/postgis/postgis.sql
psql -qX -v ON_ERROR_STOP=true -d $(GARDENDB) < $(REGRESS_INSTALLDIR)/share/contrib/postgis/spatial_ref_sys.sql
psql -qX -v ON_ERROR_STOP=true -d $(GARDENDB) < $(REGRESS_INSTALLDIR)/share/contrib/postgis/rtpostgis.sql
@echo '-------------------------------------------------'
- @echo 'Regression tests in progress (it will take time)'
- @echo 'Result output: ./regress/postgis_garden_result.txt'
+ @echo 'PostGIS garden tests in progress (it will take time)'
- psql -X -ad $(GARDENDB) < ../doc/postgis_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql > postgis_garden_result.txt 2>&1
+ psql -X -ad $(GARDENDB) < \
+ ../doc/postgis_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql \
+ > postgis_garden_result.txt 2>&1 || { \
+ tail postgis_garden_result.txt; false; }
- psql -X -ad $(GARDENDB) < ../doc/raster_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql > raster_garden_result.txt 2>&1
+ @echo '-------------------------------------------------'
+ @echo 'PostGIS Raster garden tests in progress (it will take time)'
+ ../doc/raster_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql \
+ > raster_garden_result.txt 2>&1 || { \
+ tail raster_garden_result.txt; false; }
- #dropdb $(GARDENDB)
Summary of changes:
regress/Makefile.in | 18 +++++++++++++-----
1 file changed, 13 insertions(+), 5 deletions(-)
hooks/post-receive
