[SCM] PostGIS branch master updated. 3.4.0rc1-1123-gca40cf9a7
    git at osgeo.org
    git at osgeo.org
    Fri May 24 08:44:08 PDT 2024
the project "PostGIS".
       via  ca40cf9a70e6225f5e07a167f10ce3341b90ff7d (commit)
       via  10b65858c21679cb3cf6d26a928d84e560172ed3 (commit)
      from  d29ba84cb05988ab0aa1b2da3eef90108dfae1db (commit)
revisions in full, below.
commit ca40cf9a70e6225f5e07a167f10ce3341b90ff7d
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri May 24 17:40:31 2024 +0200
    Do not print errors if upgraded database does not have postgis
diff --git a/loader/postgis.pl b/loader/postgis.pl
index a09713b33..553e22162 100644
--- a/loader/postgis.pl
+++ b/loader/postgis.pl
@@ -189,20 +189,29 @@ sub upgrade
   foreach my $db (@_)
-    print "upgrading db $db\n";
-    my $LOG=`cat <<EOF | psql -qXtA ${db}
-BEGIN;
-UPDATE pg_catalog.pg_extension SET extversion = 'ANY'
- WHERE extname IN (
-			'postgis',
-			'postgis_raster',
-			'postgis_sfcgal',
-			'postgis_topology',
-			'postgis_tiger_geocoder'
-SELECT postgis_extensions_upgrade();
-COMMIT;
-EOF`;
+    print "upgrading db $db if needed\n";
+    open(my $SESSION, "| psql -qXtA ${db} |") || die "Could not connect to database ${db}";
+    print $SESSION <<'EOF';
+DO $BODY$
+BEGIN
+  IF EXISTS ( SELECT * FROM pg_proc where proname = 'postgis_extensions_upgrade' )
+  THEN
+    UPDATE pg_catalog.pg_extension SET extversion = 'ANY'
+    WHERE extname IN (
+      'postgis',
+      'postgis_raster',
+      'postgis_sfcgal',
+      'postgis_topology',
+      'postgis_tiger_geocoder'
+    PERFORM postgis_extensions_upgrade();
+  END IF;
+END;
+$BODY$ LANGUAGE 'plpgsql';
+EOF
+    @out = <$SESSION>;
+    print @out;
+    close($SESSION);
commit 10b65858c21679cb3cf6d26a928d84e560172ed3
Date:   Fri May 24 17:39:51 2024 +0200
    Use 2 spaces indent in loader/postgis.pl
diff --git a/.editorconfig b/.editorconfig
index 3c1c705e3..a5d7b210b 100644
--- a/.editorconfig
+++ b/.editorconfig
@@ -40,6 +40,11 @@ indent_size = 2
 indent_style = space
 indent_size = 4
+# Exception: loader/postgis.pl uses 2-spaces indent
+[loader/postgis.pl]
+indent_style = space
+indent_size = 2
 # SQL files want tab indentation
 [*.{sql,sql.in}]
 indent_style = tab
Summary of changes:
 .editorconfig     |  5 +++++
 loader/postgis.pl | 37 +++++++++++++++++++++++--------------
 2 files changed, 28 insertions(+), 14 deletions(-)
hooks/post-receive
