[SCM] PostGIS branch master updated. 3.4.0rc1-1124-g762e6c82b
git at osgeo.org
git at osgeo.org
Fri May 24 09:14:06 PDT 2024
the project "PostGIS".
via 762e6c82b36588c7ffd1367ab67bfc5dce1e6f7d (commit)
from ca40cf9a70e6225f5e07a167f10ce3341b90ff7d (commit)
revisions in full, below.
commit 762e6c82b36588c7ffd1367ab67bfc5dce1e6f7d
Author: Sandro Santilli <strk at kbt.io>
Date: Fri May 24 18:12:35 2024 +0200
Simplify upgrade of postgis databases
Adds new commands: list-all and list-enabled.
Allow passing no argument to commands "status" and "upgrade" to
perform the operation on all databases.
diff --git a/NEWS b/NEWS
index afe3a39f5..55cab590e 100644
--- a/NEWS
+++ b/NEWS
@@ -44,6 +44,12 @@ Andreas Schild (German Team)
* New Features *
+ - Improvements in the 'postgis' script:
+ - new command list-enabled
+ - new command list-all
+ - command upgrade upgrades all databases that need to be
+ - command status reports status of all databases
+ (Sandro Santilli)
- #5721, Allow sharing sequences between different topologies (Lars Opsahl)
- #5667, TopoGeo_LoadGeometry (Sandro Santilli)
- #5055, add explicit <> geometry operator to prevent non-unique
diff --git a/loader/postgis.pl b/loader/postgis.pl
index 553e22162..c8973d7e7 100644
--- a/loader/postgis.pl
+++ b/loader/postgis.pl
@@ -18,9 +18,11 @@ sub usage
print qq{Usage: $0 <command> [<args>]
Commands:
help print this message and exits
- enable <database> enable PostGIS in given database
- upgrade <database> upgrade PostGIS in given database
- status <database> print PostGIS status in given database
+ list-all list all databases
+ list-enabled list PostGIS-enabled databases
+ enable <db>... enable PostGIS in given databases
+ upgrade [<db>...] upgrade PostGIS in given databases (or all)
+ status [<db>...] print PostGIS status in given databases (or all)
install-extension-upgrades [--pg_sharedir <dir>] [--extension <name>] [<from>...]
Ensure files required to upgrade PostGIS from
the given version are installed on the system.
@@ -174,6 +176,35 @@ sub install_extension_upgrades
+sub get_all_databases
+ my $ALL = `psql -qXtAc 'select datname from pg_database where datallowconn' template1`;
+ return split("\n", $ALL);
+sub list_all_databases
+ my @ALL = get_all_databases();
+ foreach (@ALL)
+ print $_ . "\n";
+sub list_enabled_databases
+ my $sql = "
+ SELECT proname
+ FROM pg_proc
+ WHERE proname = 'postgis_full_version'
+ foreach my $db (@ALL)
+ my $enabled = `psql -qXtAc "${sql}" ${db}`;
+ print $db . "\n" if $enabled ne '';
sub enable
@@ -185,11 +216,14 @@ sub enable
sub upgrade
- die "Please specify at least a database name" unless @_;
+ my @DB = @_;
- foreach my $db (@_)
+ #die "Please specify at least a database name" unless @DB;
+ @DB = get_all_databases() unless @DB;
+ foreach my $db (@DB)
- print "upgrading db $db if needed\n";
+ print "upgrading PostGIS in db $db if needed\n";
open(my $SESSION, "| psql -qXtA ${db} |") || die "Could not connect to database ${db}";
print $SESSION <<'EOF';
DO $BODY$
@@ -217,9 +251,11 @@ EOF
sub status
+ my @DB = @_;
my $sql = "
SELECT n.nspname
@@ -284,6 +320,12 @@ if ( $cmd eq "help" ) {
elsif ( $cmd eq "enable" ) {
exit enable(@ARGV);
+elsif ( $cmd eq "list-all" ) {
+ exit list_all_databases(@ARGV);
+elsif ( $cmd eq "list-enabled" ) {
+ exit list_enabled_databases(@ARGV);
elsif ( $cmd eq "upgrade" ) {
exit upgrade(@ARGV);
Summary of changes:
NEWS | 6 ++++++
loader/postgis.pl | 58 +++++++++++++++++++++++++++++++++++++++++++++++--------
2 files changed, 56 insertions(+), 8 deletions(-)
hooks/post-receive
