[PostGIS] #5736: latest releases md5 mismatch
PostGIS trac at osgeo.org
Fri May 31 03:20:12 PDT 2024
  Reporter:  strk        |      Owner:  robe
      Type:  defect      |     Status:  reopened
  Priority:  medium      |  Milestone:  Website Management, Bots
 Component:  management  |    Version:  3.4.x
Resolution:              |   Keywords:
Comment (by strk):
 Automake has a "distcheck" rule which is meant specifically to test the
 tarballs, the (automatically generated) rule creates the tarball, then
 extracts it in a temporary source dir, tags the source dir as read-only,
 configure for install in a temporary directory, builds, runs tests,
 installs, runs install tests. Maybe we can craft something like that.
 Better discuss this in a mailing list thread or separate ticket.
 For this ticket I've proceeded as you suggest and updated postgis.net MD5
 to match that of the download.osgeo.org tarball for 3.3.6
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5736#comment:11>
