[PostGIS] #5736: latest releases md5 mismatch
trac at osgeo.org
Thu May 30 20:59:09 PDT 2024
Reporter: strk | Owner: robe
Type: defect | Status: reopened
Priority: medium | Milestone: Website Management, Bots
Component: management | Version: 3.4.x
Resolution: | Keywords:
Comment (by robe):
I think this was mostly my fault, when Paul was releasing, debbie failed
to generate the tarballs, cause I had recently upgraded her which broke
the webhook that instructs her to build the tarballs. After Paul had
alerted me to the issue, I fixed but I think he was done with the tarball
generations. But I'm not absolutely sure what happened in the 3.3.6 case.
At anyrate assuming we have determined no rogue actors we should just
assume the one on download.osgeo.org is right and fix the md5/etc on
postgis.net.
I was debating if we should just automate this whole process entirely. I
think the only reason we don't is, we want to test the tarballs before
they hit download.osgeo.org cause at that point it's technically too late
since packagers (I'm know debian, possibly others) have bots watching
that location waiting to pounce to release so once it's up there, we can't
take it down since it would violate the release and require a new release.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5736#comment:10>
