[SCM] postgis.net branch json-config created. clarity-final-93-gbdab685
Fri May 31 04:29:38 PDT 2024
the project "postgis.net".
The branch, json-config has been created
        at  bdab6850107a37066ac8431e94850fa5ae6cd7c8 (commit)
commit bdab6850107a37066ac8431e94850fa5ae6cd7c8
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri May 31 13:29:13 2024 +0200
    Convert configuration from toml to json
diff --git a/config.json b/config.json
new file mode 100644
index 0000000..b780f1a
--- /dev/null
+++ b/config.json
@@ -0,0 +1,128 @@
+  "baseURL": "https://postgis.net/",
+  "title": "PostGIS",
+  "theme": "hugo-geekdoc",
+  "pygmentsUseClasses": true,
+  "pygmentsCodeFences": true,
+  "disablePathToLower": true,
+  "enableRobotsTXT": true,
+  "permalinks": {
+    "news": "/:year/:month/:title/"
+  "markup": {
+    "goldmark": {
+      "renderer": {
+        "unsafe": true
+    "tableOfContents": {
+      "startLevel": 1,
+      "endLevel": 9
+  "taxonomies": {
+    "tag": "tags",
+    "event": "events"
+  "services": {
+    "rss": {
+      "limit": 10
+  "outputFormats": {
+    "RSS": {
+      "mediatype": "application/rss",
+      "baseName": "feed"
+  "params": {
+    "geekdocToC": 2,
+    "geekdocMenuBundle": false,
+    "geekdocCollapseAllSections": false,
+    "geekdocNextPrev": true,
+    "geekdocBreadcrumb": true,
+    "geekdocSearch": true,
+    "geekdocSearchShowParent": true,
+    "geekdocAnchor": true,
+    "geekdocAnchorCopy": true,
+    "geekdocImageLazyLoading": true,
+    "geekdocOverwriteHTMLBase": false,
+    "geekdocDarkModeToggle": true,
+    "geekdocDarkModeDim": false,
+    "geekdocDarkModeCode": false,
+    "geekdocBackToTop": true,
+    "geekdocTagsToMenu": false,
+    "docLanguages": [
+      "en",
+      "ja",
+      "fr",
+      "zh_Hans",
+      "de",
+      "ko_KR",
+      "es",
+      "it",
+      "br"
+    "geekdocFileTreeSortBy": "title",
+    "geekdocContentLicense": {
+      "name": "CC BY-SA 4.0",
+      "link": "https://creativecommons.org/licenses/by-sa/4.0/"
+    "postgisMenu": [
+        "name": "Documentation",
+        "href": "/documentation"
+        "name": "Community",
+        "href": "/community"
+        "name": "Development",
+        "href": "/support"
+    "postgis": {
+      "version": "3.3.4",
+      "release_docs": "https://download.osgeo.org/postgis/docs",
+      "release_source": "https://download.osgeo.org/postgis/source",
+      "release_notes": "https://git.osgeo.org/gitea/postgis/postgis/raw/tag",
+      "source_dev_branch": "https://git.osgeo.org/gitea/postgis/postgis/src/branch/master",
+      "site_docs": "/docs",
+      "dev_download": "/stuff",
+      "releases": {
+        "dev": {
+          "minor": "3.5",
+          "dev": "3.5.0dev",
+          "tag": "3.5.0dev",
+          "is_dev": true
+        "34": {
+          "minor": "3.4",
+          "dev": "3.4.3dev",
+          "tag": "3.4.2"
+        "33": {
+          "minor": "3.3",
+          "dev": "3.3.7dev",
+          "tag": "3.3.6"
+        "32": {
+          "minor": "3.2",
+          "dev": "3.2.8dev",
+          "tag": "3.2.7"
+        "31": {
+          "minor": "3.1",
+          "dev": "3.1.12dev",
+          "tag": "3.1.11"
+        "30": {
+          "minor": "3.0",
+          "dev": "3.0.12dev",
+          "tag": "3.0.11"
diff --git a/config.toml b/config.toml
deleted file mode 100644
index 13caa9a..0000000
--- a/config.toml
+++ /dev/null
@@ -1,205 +0,0 @@
-baseURL = "https://postgis.net/"
-title = "PostGIS"
-theme = "hugo-geekdoc"
-# Required to get well formatted code blocks
-pygmentsUseClasses = true
-pygmentsCodeFences = true
-disablePathToLower = true
-# enableGitInfo = true
-# Required if you want to render robots.txt template
-enableRobotsTXT = true
-[permalinks]
-  news = '/:year/:month/:title/'
-[markup]
-  [markup.goldmark.renderer]
-    # Needed for mermaid shortcode
-    unsafe = true
-  [markup.tableOfContents]
-    startLevel = 1
-    endLevel = 9
-[taxonomies]
-  tag = "tags"
-  event = "events"
-[services.rss]
-  limit = 10
-[outputFormats]
-[outputFormats.RSS]
-  mediatype = "application/rss"
-  baseName = "feed"
-[params]
-  # (Optional, default 6) Set how many table of contents levels to be showed on page.
-  # Use false to hide ToC, note that 0 will default to 6 (https://gohugo.io/functions/default/)
-  # You can also specify this parameter per page in front matter.
-  geekdocToC = 2
-  # (Optional, default static/brand.svg) Set the path to a logo for the Geekdoc
-  # relative to your 'static/' folder.
-  # We ignore this value in the CSS
-  #geekdocLogo = "postgis-logo-horizontal.png"
-  # (Optional, default false) Render menu from data file in 'data/menu/main.yaml'.
-  # See also https://geekdocs.de/usage/menus/#bundle-menu.
-  geekdocMenuBundle = false
-  # (Optional, default false) Collapse all menu entries, can not be overwritten
-  # per page if enabled. Can be enabled per page via 'geekdocCollapseSection'.
-  geekdocCollapseAllSections = false
-  # (Optional, default true) Show page navigation links at the bottom of each
-  # docs page (bundle menu only).
-  geekdocNextPrev = true
-  # (Optional, default true) Show a breadcrumb navigation bar at the top of each docs page.
-  geekdocBreadcrumb = true
-  # (Optional, default none) Set source repository location. Used for 'Edit page' links.
-  #geekdocRepo = "https://git.osgeo.org/gitea/postgis/postgis.net"
-  # (Optional, default none) Enable 'Edit page' links. Requires 'GeekdocRepo' param
-  # and the path must point to the parent directory of the 'content' folder.
-  #geekdocEditPath = "/src/branch/website/content"
-  # (Optional, default true) Enables search function with flexsearch.
-  # Index is built on the fly and might slow down your website.
-  geekdocSearch = true
-  # (Optional, default false) Display search results with the parent folder as prefix. This
-  # option allows you to distinguish between files with the same name in different folders.
-  # NOTE: This parameter only applies when 'geekdocSearch = true'.
-  geekdocSearchShowParent = true
-  # (Optional, default none) Add a link to your Legal Notice page to the site footer.
-  # It can be either a remote url or a local file path relative to your content directory.
-  #geekdocLegalNotice = "https://blog.example.com/legal"
-  # (Optional, default none) Add a link to your Privacy Policy page to the site footer.
-  #geekdocPrivacyPolicy = "/privacy"
-  # (Optional, default true) Add an anchor link to headlines.
-  geekdocAnchor = true
-  # (Optional, default true) Copy anchor url to clipboard on click.
-  geekdocAnchorCopy = true
-  # (Optional, default true) Enable or disable image lazy loading for images rendered
-  # by the 'img' shortcode.
-  geekdocImageLazyLoading = true
-  # (Optional, default false) Set HTMl <base> to .Site.BaseURL if enabled. It might be required
-  # if a subdirectory is used within Hugos BaseURL.
-  # See https://developer.mozilla.org/de/docs/Web/HTML/Element/base.
-  geekdocOverwriteHTMLBase = false
-  # (Optional, default true) Enable or disable the JavaScript based color theme toggle switch. The CSS based
-  # user preference mode still works.
-  geekdocDarkModeToggle = true
-  # (Optional, default false) Auto-decrease brightness of images and add a slightly grayscale to avoid
-  # bright spots while using the dark mode.
-  geekdocDarkModeDim = false
-  # (Optional, default false) Enforce code blocks to always use the dark color theme.
-  geekdocDarkModeCode = false
-  # (Optional, default true) Display a "Back to top" link in the site footer.
-  geekdocBackToTop = true
-  # (Optional, default false) Enable or disable adding tags for post pages automatically to the navigation sidebar.
-  geekdocTagsToMenu = false
-  docLanguages = ['en', 'ja', 'fr', 'zh_Hans', 'de', 'ko_KR', 'es', 'it', 'br']
-  # (Optional, default 'title') Configure how to sort file-tree menu entries. Possible options are 'title', 'linktitle',
-  # 'date', 'publishdate', 'expirydate' or 'lastmod'. Every option can be used with a reverse modifier as well
-  # e.g. 'title_reverse'.
-  geekdocFileTreeSortBy = "title"
-  # (Optional, default none) Adds a "Content licensed under <license>" line to the footer.
-  # Could be used if you want to define a default license for your content.
-  [params.geekdocContentLicense]
-    name = "CC BY-SA 4.0"
-    link = "https://creativecommons.org/licenses/by-sa/4.0/"
-  [[params.postgisMenu]]
-  name = "Documentation"
-  href = "/documentation"
-  name = "Community"
-  href = "/community"
-  name = "Development"
-  href = "/support"
-  # [[params.postgisMenu]]
-  # name = "Home"
-  # href = "/"
-  [params.postgis]
-    version = "3.3.4"
-    release_docs =  "https://download.osgeo.org/postgis/docs"
-    release_source = "https://download.osgeo.org/postgis/source"
-    release_notes = "https://git.osgeo.org/gitea/postgis/postgis/raw/tag"
-    source_dev_branch = "https://git.osgeo.org/gitea/postgis/postgis/src/branch/master"
-    site_docs =  "/docs"
-    dev_download = "/stuff"
-  [params.postgis.releases]
-    [params.postgis.releases.dev]
-      minor = "3.5"
-      dev = "3.5.0dev"
-      tag = "3.5.0dev"
-      is_dev = true
-    [params.postgis.releases.34]
-      minor = "3.4"
-      dev = "3.4.3dev"
-      tag = "3.4.2"
-    [params.postgis.releases.33]
-      minor = "3.3"
-      dev = "3.3.7dev"
-      tag = "3.3.6"
-    [params.postgis.releases.32]
-      minor = "3.2"
-      dev = "3.2.8dev"
-      tag = "3.2.7"
-    [params.postgis.releases.31]
-      minor = "3.1"
-      dev = "3.1.12dev"
-      tag = "3.1.11"
-    [params.postgis.releases.30]
-      minor = "3.0"
-      dev = "3.0.12dev"
-      tag = "3.0.11"
-    # [params.postgis.releases.25]
-    #   minor = "2.5"
-    #   dev = "2.5.11"
-    #   tag = "2.5.11"
-    #   eol = true
-    # [params.postgis.releases.24]
-    #   minor = "2.4"
-    #   dev = "2.4.10"
-    #   tag = "2.4.10"
-    #   eol = true
-    # [params.postgis.releases.23]
-    #   minor = "2.3"
-    #   dev = "2.3.11"
-    #   tag = "2.3.11"
-    #   eol = true
hooks/post-receive
postgis.net
