[SCM] PostGIS branch stable-3.4 updated. 3.4.2-39-gd4306cb93
git at osgeo.org
git at osgeo.org
Fri May 31 15:18:42 PDT 2024
the project "PostGIS".
The branch, stable-3.4 has been updated
via d4306cb9351d6d343fdea702c075911450e44ec6 (commit)
from 58bcf7f1c656b8c61b05a390335ef0ccd42dc59e (commit)
revisions in full, below.
commit d4306cb9351d6d343fdea702c075911450e44ec6
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri May 31 14:40:35 2024 -0700
Only run pgaudit extension install test for PgSQL >= 15, references #5611
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index f011f3695..81b69789f 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -68,12 +68,19 @@ $$ LANGUAGE 'plpgsql';
DO $$
DECLARE
pgalog text;
+ pgvernum integer;
BEGIN
+ SHOW server_version_num INTO pgvernum;
+ IF pgvernum >= 150000
+ THEN
+ RAISE DEBUG 'pgsql version % >= 150000, skipping pgaudit checks', pgvernum;
+ RETURN;
+ END IF;
SHOW pgaudit.log INTO pgalog;
RAISE DEBUG 'pgaudit is installed, pgaudit.log is set to ''%''', pgalog;
IF pg_catalog.lower(pgalog) != 'none'
THEN
- RAISE EXCEPTION 'PostGIS installation stopped: pgaudit.log is set to ''%''. Set pgaudit.log to ''none'' before installing PostGIS. You may re-enable pgaudit after installation is complete.', pgalog;
+ RAISE EXCEPTION 'PostGIS installation stopped: pgaudit.log is set to ''%''. SET pgaudit.log = ''none'' before installing PostGIS. You may re-enable pgaudit after installation is complete.', pgalog;
END IF;
EXCEPTION
WHEN undefined_object THEN
Summary of changes:
postgis/postgis.sql.in | 9 ++++++++-
1 file changed, 8 insertions(+), 1 deletion(-)
hooks/post-receive
