[SCM] PostGIS branch master updated. 3.4.0rc1-1134-g91ad04d38
git at osgeo.org
git at osgeo.org
Fri May 31 15:19:06 PDT 2024
the project "PostGIS".
via 91ad04d38f3a8cedc6140185389ff2881338c762 (commit)
from 063edf72facdce90c2a1019db100292137e29905 (commit)
revisions in full, below.
commit 91ad04d38f3a8cedc6140185389ff2881338c762
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri May 31 14:18:40 2024 -0700
Remove pgaudit check from extension script, as pgaudit no longer slams the log with messages on extension install, references #5611
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 9677eeccc..89626c9dd 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -62,26 +62,6 @@ END
$$ LANGUAGE 'plpgsql';
--- Check that pgaudit is disabled or not installed
--- Running extension creation with pgaudit enabled will result in a
--- multi-gigabyte log storm for PgSQL <= 14
-DO $$
-DECLARE
- pgalog text;
-BEGIN
- SHOW pgaudit.log INTO pgalog;
- RAISE DEBUG 'pgaudit is installed, pgaudit.log is set to ''%''', pgalog;
- IF pg_catalog.lower(pgalog) != 'none'
- THEN
- RAISE EXCEPTION 'PostGIS installation stopped: pgaudit.log is set to ''%''. Set pgaudit.log to ''none'' before installing PostGIS. You may re-enable pgaudit after installation is complete.', pgalog;
- END IF;
-EXCEPTION
- WHEN undefined_object THEN
- RAISE DEBUG 'pgaudit is not installed';
-END;
-- Let the user know about a deprecated signature and its new name, if any
CREATE OR REPLACE FUNCTION _postgis_deprecate(oldname text, newname text, version text)
RETURNS void AS
Summary of changes:
postgis/postgis.sql.in | 20 --------------------
1 file changed, 20 deletions(-)
hooks/post-receive
