[SCM] PostGIS branch master updated. 3.5.0-57-g8f85eba00
Thu Nov 14 03:29:19 PST 2024
the project "PostGIS".
       via  8f85eba000b9f029b1c2eb03a6749c31bb95d794 (commit)
       via  e65a97beb5351ca650e7b8f6a18fa8a9023c8331 (commit)
      from  4f1e40efd167b6d45be0634368a8e98610915977 (commit)
revisions in full, below.
commit 8f85eba000b9f029b1c2eb03a6749c31bb95d794
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Nov 14 12:20:22 2024 +0100
    Update translation template
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index 26f9d1b0b..76bbd12b7 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -6,7 +6,7 @@ msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2024-09-29 05:23+0000\n"
+"POT-Creation-Date: 2024-11-14 11:19+0000\n"
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -7986,6 +7986,11 @@ msgstr ""
 msgid "David Techer"
 msgstr ""
+#. Tag: member
+#, no-c-format
+msgid "Dian M Fay"
+msgstr ""
 #. Tag: member
 #, no-c-format
 msgid "Dmitry Vasilyev"
@@ -12015,10 +12020,9 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"While not OGC-compliant, <varname>ST_MakePoint</varname> is faster and more "
-"precise than <xref linkend=\"ST_GeomFromText\"/> and <xref "
-"linkend=\"ST_PointFromText\"/>. It is also easier to use for numeric "
-"coordinate values."
+"While not OGC-compliant, <varname>ST_MakePoint</varname> is faster than "
+"<xref linkend=\"ST_GeomFromText\"/> and <xref linkend=\"ST_PointFromText\"/"
+">. It is also easier to use for numeric coordinate values."
 msgstr ""
 #. Tag: para
@@ -14446,6 +14450,15 @@ msgid ""
 "set at global or database level."
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"For more examples of usage refer to <link xlink:href=\"https://www."
+"postgresql.org/docs/current/sql-set.html\">SQL SET</link> and <link xlink:"
+"href=\"https://www.postgresql.org/docs/current/sql-altersystem.html\">SQL "
+"ALTER SYSTEM</link>"
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
@@ -14611,30 +14624,22 @@ msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "Set and reset <varname>postgis.gdal_enabled_drivers</varname>"
+msgid ""
+"To set and reset <varname>postgis.gdal_enabled_drivers</varname> for current "
+"session"
 msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "Sets backend for all new connections to database"
+msgid "Set for all new connections to a specific database to specific drivers"
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"Sets default enabled drivers for all new connections to server. Requires "
-"super user access and PostgreSQL 9.4+. Also note that database, session, and "
-"user settings override this."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Enable all GDAL Drivers"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Disable all GDAL Drivers"
+"Setting for whole database cluster to enable all drivers. Requires super "
+"user access. Also note that database, session, and user settings override "
+"this."
 msgstr ""
 #. Tag: para
@@ -14691,14 +14696,14 @@ msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "Set for specific database"
+msgid "Set for all new connections to a specific database"
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"Setting for whole database cluster. You need to reconnect to the database "
-"for changes to take effect."
+"Setting for whole database cluster. Requires super user access. Also note "
+"that database, session, and user settings override this."
 msgstr ""
 #. Tag: refpurpose
@@ -16971,9 +16976,9 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"Enhanced: 2.1.0 improved speed for geography. See <link xlink:href=\"http://"
-"boundlessgeo.com/2012/07/making-geography-faster/\">Making Geography faster</"
-"link> for details."
+"Enhanced: 2.1.0 improved speed for geography. See <link xlink:href=\"https://"
+"web.archive.org/web/20160827203903/http://boundlessgeo.com/2012/07/making-"
+"geography-faster/\">Making Geography faster</link> for details."
 msgstr ""
 #. Tag: para
@@ -23999,6 +24004,29 @@ msgid ""
 "<xref linkend=\"RT_ST_AsJPEG\"/>, <xref linkend=\"RT_ST_SRID\"/>"
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Aggregate. Renders PostGIS geometries into a new raster."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Returns a single-band raster containing the rendered version of all incoming "
+"geometries, each with its associated value."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Availability: 3.6.0"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+", <xref linkend=\"RT_ST_DumpAsPolygons\"/>, <xref linkend=\"RT_ST_Union\"/>"
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
@@ -25263,10 +25291,11 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-", <xref linkend=\"RT_ST_DumpAsPolygons\"/>, <xref linkend=\"RT_ST_NumBands\"/"
-">, <xref linkend=\"RT_ST_PixelAsPolygon\"/>, <xref linkend=\"RT_ST_ScaleX\"/"
-">, <xref linkend=\"RT_ST_ScaleY\"/>, <xref linkend=\"RT_ST_UpperLeftX\"/>, "
-"<xref linkend=\"RT_ST_UpperLeftY\"/>, <xref linkend=\"RT_ST_SRID\"/>, <xref "
+", <xref linkend=\"RT_ST_SetValue\"/>, <xref linkend=\"RT_ST_DumpAsPolygons\"/"
+">, <xref linkend=\"RT_ST_NumBands\"/>, <xref "
+"linkend=\"RT_ST_PixelAsPolygon\"/>, <xref linkend=\"RT_ST_ScaleX\"/>, <xref "
+"linkend=\"RT_ST_ScaleY\"/>, <xref linkend=\"RT_ST_UpperLeftX\"/>, <xref "
+"linkend=\"RT_ST_UpperLeftY\"/>, <xref linkend=\"RT_ST_SRID\"/>, <xref "
 "linkend=\"ST_AsText\"/>, <xref linkend=\"ST_Point\"/>, <xref "
 "linkend=\"ST_MakeEnvelope\"/>, <xref linkend=\"ST_Intersects\"/>, <xref "
 "linkend=\"ST_Intersection\"/>"
@@ -29190,8 +29219,8 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-", <xref linkend=\"RT_ST_Value\"/>, <xref linkend=\"RT_ST_Polygon\"/>, <xref "
-"linkend=\"RT_ST_ValueCount\"/>"
+", <xref linkend=\"RT_ST_AsRasterAgg\"/>, <xref linkend=\"RT_ST_Value\"/>, "
+"<xref linkend=\"RT_ST_Polygon\"/>, <xref linkend=\"RT_ST_ValueCount\"/>"
 msgstr ""
 #. Tag: refpurpose
@@ -31443,14 +31472,6 @@ msgstr ""
 msgid "Availability: 1.5.0 support for geography was introduced"
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"blog.opengeo.org/2012/07/12/making-geography-faster/\">Making Geography "
-"faster</link> for details."
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid "Enhanced: 2.1.0 support for curved geometries was introduced."
commit e65a97beb5351ca650e7b8f6a18fa8a9023c8331
Date:   Thu Nov 14 12:27:24 2024 +0100
    Drop the scary "more precise" note about MakePoint vs. GeomFromText
diff --git a/doc/reference_constructor.xml b/doc/reference_constructor.xml
index 1201cb62e..63c250664 100644
--- a/doc/reference_constructor.xml
+++ b/doc/reference_constructor.xml
@@ -401,15 +401,15 @@ SELECT gps.track_id, ST_MakeLine(gps.geom) As geom
 			<para>
-			faster and more precise than <xref linkend="ST_GeomFromText"/>
+			faster than <xref linkend="ST_GeomFromText"/>
 			and <xref linkend="ST_PointFromText"/>.
 			It is also easier to use for numeric coordinate values.</para>
 			<note><para>For geodetic coordinates, <varname>X</varname> is longitude and <varname>Y</varname> is latitude</para></note>
 			<note><para>
-			The functions
-			<xref linkend="ST_Point"/>, <xref linkend="ST_PointZ"/>, <xref linkend="ST_PointM"/>, and <xref linkend="ST_PointZM"/>
+			The functions
+			<xref linkend="ST_Point"/>, <xref linkend="ST_PointZ"/>, <xref linkend="ST_PointM"/>, and <xref linkend="ST_PointZM"/>
 			can be used to create points with a given SRID.
 			</para></note>
@@ -463,7 +463,7 @@ result
 		<refsection>
 			<title>Description</title>
-			<para>Creates a point with X, Y and M (measure) ordinates.
+			<para>Creates a point with X, Y and M (measure) ordinates.
 			Use <xref linkend="ST_MakePoint"/> to make points with XY, XYZ, or XYZM coordinates.</para>
 			<para>Use <xref linkend="ST_SetSRID"/> to specify a SRID for the created point.</para>
@@ -471,8 +471,8 @@ result
 			<note><para>
-			The functions
-			<xref linkend="ST_PointM"/>, and <xref linkend="ST_PointZM"/>
+			The functions
+			<xref linkend="ST_PointM"/>, and <xref linkend="ST_PointZM"/>
 			can be used to create points with an M value and a given SRID.
 			</para></note>
@@ -729,8 +729,8 @@ SELECT ST_Transform( ST_Point( 3637510, 3014852, 2273), 4326)::geography;</progr
 	  <refsection>
 		<title>See Also</title>
-		<para><xref linkend="ST_MakePoint"/>,
-			<xref linkend="ST_PointZ"/>, <xref linkend="ST_PointM"/>, <xref linkend="ST_PointZM"/>,
+		<para><xref linkend="ST_MakePoint"/>,
+			<xref linkend="ST_PointZ"/>, <xref linkend="ST_PointM"/>, <xref linkend="ST_PointZM"/>,
 			<xref linkend="ST_SetSRID"/>, <xref linkend="ST_Transform"/></para>
 	  </refsection>
 	</refentry>
Summary of changes:
 doc/po/templates/postgis-manual.pot | 101 ++++++++++++++++++++++--------------
 doc/reference_constructor.xml       |  16 +++---
 2 files changed, 69 insertions(+), 48 deletions(-)
hooks/post-receive
