[PostGIS] #5782: TopoGeo_addLinestring corrups topology: adjacent edges 33 and -32 bind different face (1 and 0)
trac at osgeo.org
Tue Oct 1 01:54:49 PDT 2024
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.4.4
Component: topology | Version:
Resolution: | Keywords:
Comment (by strk):
The mindistance-no-construct-point branch was now merged into the master
branch with commit [290fffd11dac294431056e6d152098ac0afe60de/git] with
regress tests.
I did not analyze the topology_test_02.sql test yet but if as you report
it was succeeding with the GEOS-implemented min distance and it is failing
with the PostGIS version of it then it is not expected I guess.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5782#comment:34>
