[PostGIS] #5786: Side-location conflict: new edge starts in face 42 and ends in face 10
trac at osgeo.org
Thu Oct 3 02:56:03 PDT 2024
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.1
Component: topology | Version: master
Resolution: | Keywords: robustness
Comment (by strk):
The problem seems to be in the experimental edge merging code. The code
correctly finds that splitting the lower edge (edge 1) on the same new
node as the upper edge (edge 2) ends up collapsing to the newly created
edge 3 on the last part of original edge 2, but fails to set the side
face:
=# select edge_id, left_face, right_face from t5786.edge;
edge_id | left_face | right_face
2 | 0 | 1
3 | 1 | 1
1 | 0 | 1
The correct labeling for edge_id=3 would be that both left and right face
are 0.
These are the debug log of the wrong operation:
[.././../liblwgeom/topo/lwgeom_topo.c:_lwt_SnapEdgeToExistingNode:5411]
Existing edge 3 (post-modEdgeSplit) next_right:-2, next_left:1,
face_right:1, face_left:0
[.././../liblwgeom/topo/lwgeom_topo.c:_lwt_SnapEdgeToExistingNode:5446]
Setting nextEdge/sideFace of CCW edge -2 to 1/0
[.././../liblwgeom/topo/lwgeom_topo.c:_lwt_SnapEdgeToExistingNode:5472]
Will update next_left/face_left of incoming CCW edge 2 to 1/0
[.././../liblwgeom/topo/lwgeom_topo.c:_lwt_SnapEdgeToExistingNode:5505]
Setting sideFace of CW edge 3 to 1
Inn particular, the last line shows the wrong operation
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5786#comment:14>
