[PostGIS] #5786: Side-location conflict: new edge starts in face 42 and ends in face 10
trac at osgeo.org
Thu Oct 3 07:13:13 PDT 2024
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.1
Component: topology | Version: master
Resolution: | Keywords: robustness
Comment (by strk):
It looks like the code having robustness issues is the one determining
order of edges around the new node:
> Component 1 of split edge 1 next CW is 3, next CCW is -2
Truth is next CW should be -2 and next CCW should be 3
The code in charge of telling is _lwt_FindAdjacentEdges
We have the subject edge found to have an azimuth of
4.68811780780983, edge 3 found to have azimuth of 1.54652515429415 and
edge 2 found to have azimuth of
4.68811780778147
This means edge 2 is found to be BELOW the subject edge.
This should never happen when no edge crossing is detected, and that check
is performed successfully:
> [.././../liblwgeom/topo/lwgeom_topo.c:lwt_ChangeEdgeGeom:3384]
lwt_ChangeEdgeGeom: edge crossing check passed
I should note that raising by 1e-14 the Y value of the middle point of
edge 2 fixes the issue, confirming this is definitely a problem of
numerical robustness
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5786#comment:15>
