[PostGIS] #5786: Side-location conflict: new edge starts in face 42 and ends in face 10
trac at osgeo.org
Thu Oct 3 07:39:29 PDT 2024
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.1
Component: topology | Version: master
Resolution: | Keywords: robustness
Comment (by strk):
Edge 2 is found to be ABOVE edge 1 before the snapping:
=# select edge_id, st_azimuth(st_pointn(geom,1),st_pointn(geom,2)) from
t5786.edge where edge_id = 1;
edge_id | st_azimuth
1 | 4.688117807826012
=# select edge_id, st_azimuth(st_pointn(geom,3),st_pointn(geom,2)) from
t5786.edge where edge_id = 2;
2 | 4.688117807826215
Once both edges are snapped to the new node, edge 2 is found to be BELOW
edge 1:
=# update t5786.edge set geom = ST_Snap(geom, 'POINT(11.812029186127067
59.7793864213727)', 1e-6);
UPDATE 2
=# select edge_id, st_azimuth(st_pointn(geom,2),st_pointn(geom,3)) from
1 | 4.688117807809833
(1 row)
strk at strk=# select edge_id,
st_azimuth(st_pointn(geom,3),st_pointn(geom,2)) from t5786.edge where
edge_id = 2;
2 | 4.688117807781473
(1 row)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5786#comment:16>
