[PostGIS] #5793: Crash on Buffer of Empty array on PG17
PostGIS trac at osgeo.org
Wed Oct 9 10:54:23 PDT 2024
  Reporter:  pramsey  |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.5.1
 Component:  postgis  |    Version:  3.4.x
Resolution:           |   Keywords:  pg17
Comment (by pramsey):
 Oh interesting. I have a stack trace and no postgis code is touched.
 Exercise for the reader: reconstruct this crash using only core functions.
   * frame #0: 0x00000001053a945c
 postgres`find_base_rel(root=0x0000000000000000, relid=1) at
 relnode.c:419:38
     frame #1: 0x00000001056c5d64
 postgres`examine_variable(root=0x0000000000000000,
 node=0x000000011e8092c8, varRelid=0, vardata=0x000000016afc76f0) at
 selfuncs.c:5073:14
     frame #2: 0x00000001056c8474
 postgres`estimate_array_length(root=0x0000000000000000,
 arrayexpr=0x000000011e8092c8) at selfuncs.c:2164:3
     frame #3: 0x000000010531cbec
 postgres`cost_qual_eval_walker(node=0x000000011e809dc8,
 context=0x000000016afc82e0) at costsize.c:4861:5
     frame #4: 0x000000010529f46c
 postgres`expression_tree_walker_impl(node=0x000000011e809ff8,
 walker=(postgres`cost_qual_eval_walker at costsize.c:4681),
 context=0x000000016afc82e0) at nodeFuncs.c:2524:9
     frame #5: 0x000000010529e404
 postgres`expression_tree_walker_impl(node=0x000000011e80a048,
 context=0x000000016afc82e0) at nodeFuncs.c:2193:9
     frame #6: 0x000000010531cf84
 postgres`cost_qual_eval_walker(node=0x000000011e80a048,
 context=0x000000016afc82e0) at costsize.c:4945:9
     frame #7: 0x000000010529f46c
 postgres`expression_tree_walker_impl(node=0x000000011e80a098,
     frame #8: 0x000000010529e404
 postgres`expression_tree_walker_impl(node=0x000000011e80a0e8,
     frame #9: 0x000000010531cf84
 postgres`cost_qual_eval_walker(node=0x000000011e80a0e8,
     frame #10: 0x0000000105315b18
 postgres`cost_qual_eval(cost=0x000000016afc8378, quals=0x000000011e80b768,
 root=0x0000000000000000) at costsize.c:4655:3
     frame #11: 0x000000010538fab0 postgres`inline_function(funcid=18459,
 result_type=18318, result_collid=0, input_collid=0,
 args=0x000000011e80a138, funcvariadic=false,
 func_tuple=0x00000001480ab478, context=0x000000016afca1b8) at
 clauses.c:4816:4
     frame #12: 0x000000010538e59c postgres`simplify_function(funcid=18459,
 result_type=18318, result_typmod=-1, result_collid=0, input_collid=0,
 args_p=0x000000016afc89f0, funcvariadic=false, process_args=true,
 allow_non_const=true, context=0x000000016afca1b8) at clauses.c:4133:13
     frame #13: 0x0000000105389fa4
 postgres`eval_const_expressions_mutator(node=0x000000011e809788,
 context=0x000000016afca1b8) at clauses.c:2591:14
     frame #14: 0x00000001052a1f94
 postgres`expression_tree_mutator_impl(node=0x000000011e8097d8,
 mutator=(postgres`eval_const_expressions_mutator at clauses.c:2442),
 context=0x000000016afca1b8) at nodeFuncs.c:3459:5
     frame #15: 0x000000010538c178
 postgres`eval_const_expressions_mutator(node=0x000000011e8097d8,
 context=0x000000016afca1b8) at clauses.c:3711:9
     frame #16: 0x00000001052a236c
 postgres`expression_tree_mutator_impl(node=0x000000011e809828,
 context=0x000000016afca1b8) at nodeFuncs.c:3545:12
     frame #17: 0x000000010538c178
 postgres`eval_const_expressions_mutator(node=0x000000011e809828,
     frame #18: 0x00000001053898bc
 postgres`eval_const_expressions(root=0x000000011e809918,
 node=0x000000011e809828) at clauses.c:2266:9
     frame #19: 0x0000000105358664
 postgres`preprocess_expression(root=0x000000011e809918,
 expr=0x000000011e809828, kind=1) at planner.c:1175:10
     frame #20: 0x0000000105357388
 postgres`subquery_planner(glob=0x000000012e016580,
 parse=0x000000012e016690, parent_root=0x0000000000000000,
 hasRecursion=false, tuple_fraction=0, setops=0x0000000000000000) at
 planner.c:842:3
     frame #21: 0x000000010535635c
 postgres`standard_planner(parse=0x000000012e016690, query_string="select
 st_buffer(st_collect(array_agg (tab.shape)::geometry[])::geography, 10.0)
 from tab;", cursorOptions=2048, boundParams=0x0000000000000000) at
 planner.c:421:9
     frame #22: 0x0000000105356078
 postgres`planner(parse=0x000000012e016690, query_string="select
 planner.c:282:12
     frame #23: 0x00000001054fe95c
 postgres`pg_plan_query(querytree=0x000000012e016690, query_string="select
 postgres.c:908:9
     frame #24: 0x00000001054feb3c
 postgres`pg_plan_queries(querytrees=0x000000011e8098c8,
 query_string="select st_buffer(st_collect(array_agg
 (tab.shape)::geometry[])::geography, 10.0) from tab;", cursorOptions=2048,
 boundParams=0x0000000000000000) at postgres.c:1000:11
     frame #25: 0x0000000105502684
 postgres`exec_simple_query(query_string="select
 from tab;") at postgres.c:1197:19
     frame #26: 0x00000001055018f4 postgres`PostgresMain(dbname="pramsey",
 username="pramsey") at postgres.c:4767:7
     frame #27: 0x00000001054f8fc0 postgres`BackendMain(startup_data="",
 startup_data_len=4) at backend_startup.c:105:2
     frame #28: 0x00000001053d6974
 postgres`postmaster_child_launch(child_type=B_BACKEND, startup_data="",
 startup_data_len=4, client_sock=0x000000016afcaab8) at
 launch_backend.c:277:3
     frame #29: 0x00000001053de840
 postgres`BackendStartup(client_sock=0x000000016afcaab8) at
 postmaster.c:3593:8
     frame #30: 0x00000001053db48c postgres`ServerLoop at
 postmaster.c:1674:6
     frame #31: 0x00000001053da358 postgres`PostmasterMain(argc=3,
 argv=0x00006000026e2d80) at postmaster.c:1372:11
     frame #32: 0x000000010525ed00 postgres`main(argc=3,
 argv=0x00006000026e2d80) at main.c:197:3
     frame #33: 0x000000018792b154 dyld`start + 2476
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5793#comment:5>
