[SCM] PostGIS branch stable-3.5 updated. 3.5.0-9-g319935310
git at osgeo.org
git at osgeo.org
Thu Oct 10 08:19:36 PDT 2024
the project "PostGIS".
The branch, stable-3.5 has been updated
via 31993531006d95721bed3328d0d511e9d91f102e (commit)
from 77eddb114e21ec0b7eba2b5caa496d7e864ef247 (commit)
revisions in full, below.
commit 31993531006d95721bed3328d0d511e9d91f102e
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Oct 9 10:49:21 2024 +0200
Fix more debug formats, add more TODO comments
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index 38721c222..bfdcf137e 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -984,7 +984,7 @@ _lwt_EdgeSplit( LWT_TOPOLOGY* topo, LWT_ELEMID edge, LWPOINT* pt, int skipISOChe
LWDEBUGG(2, lwline_as_lwgeom(oldedge[0]->geom), "Edge to be split");
if ( ! *oldedge )
- LWDEBUGF(1, "lwt_be_getEdgeById returned NULL and set i=%d", i);
+ LWDEBUGF(1, "lwt_be_getEdgeById returned NULL and set i=%lu", i);
if (i == UINT64_MAX)
PGTOPO_BE_ERROR();
@@ -1563,7 +1563,7 @@ _lwt_FindAdjacentEdges( LWT_TOPOLOGY* topo, LWT_ELEMID node, edgeend *data,
return 0;
- LWDEBUGF(1, "getEdgeByNode returned %d edges, minaz=%g, maxaz=%g",
+ LWDEBUGF(1, "getEdgeByNode returned %lu edges, minaz=%g, maxaz=%g",
numedges, minaz, maxaz);
/* For each incident edge-end (1 or 2): */
@@ -1829,7 +1829,7 @@ _lwt_MakeRingShell(LWT_TOPOLOGY *topo, LWT_ELEMID *signed_edge_ids, uint64_t num
for ( i=0; i<num_signed_edge_ids; ++i )
LWT_ELEMID eid = signed_edge_ids[i];
- LWDEBUGF(2, "Edge %d in ring is edge %" LWTFMT_ELEMID, i, eid);
+ LWDEBUGF(2, "Edge %lu in ring is edge %" LWTFMT_ELEMID, i, eid);
LWT_ISO_EDGE *edge = NULL;
POINTARRAY *epa;
for ( j=0; j<numedges; ++j )
@@ -1918,7 +1918,7 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
PGTOPO_BE_ERROR();
return -2;
- LWDEBUGF(1, "getRingEdges returned %d edges", num_signed_edge_ids);
+ LWDEBUGF(1, "getRingEdges returned %lu edges", num_signed_edge_ids);
/* You can't get to the other side of an edge forming a ring */
for (i=0; i<num_signed_edge_ids; ++i) {
@@ -2085,7 +2085,7 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
PGTOPO_BE_ERROR();
return -2;
- LWDEBUGF(1, "_lwt_AddFaceSplit: lwt_be_getEdgeByFace(%d) returned %d edges", face, numfaceedges);
+ LWDEBUGF(1, "_lwt_AddFaceSplit: lwt_be_getEdgeByFace(%" LWTFMT_ELEMID ") returned %lu edges", face, numfaceedges);
if ( numfaceedges )
@@ -2109,7 +2109,7 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
if ( seid == e->edge_id )
/* IDEA: remove entry from signed_edge_ids, to speed next loop ? */
- LWDEBUGF(1, "Edge %d is a known forward edge of the new ring", e->edge_id);
+ LWDEBUGF(1, "Edge %" LWTFMT_ELEMID " is a known forward edge of the new ring", e->edge_id);
forward_edges[forward_edges_count].edge_id = e->edge_id;
forward_edges[forward_edges_count++].face_left = newface.face_id;
found++;
@@ -2118,7 +2118,7 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
else if ( -seid == e->edge_id )
- LWDEBUGF(1, "Edge %d is a known backward edge of the new ring", e->edge_id);
+ LWDEBUGF(1, "Edge %" LWTFMT_ELEMID " is a known backward edge of the new ring", e->edge_id);
backward_edges[backward_edges_count].edge_id = e->edge_id;
backward_edges[backward_edges_count++].face_right = newface.face_id;
found++;
@@ -2126,7 +2126,7 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
if ( found ) continue;
- LWDEBUGF(1, "Edge %d is not a known edge of the new ring", e->edge_id);
+ LWDEBUGF(1, "Edge %" LWTFMT_ELEMID " is not a known edge of the new ring", e->edge_id);
/* Check if the edge is now binding a different face */
@@ -2145,7 +2145,7 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
* shellbox to do it here */
contains = ptarray_contains_point(pa, &ep);
- LWDEBUGF(1, "Edge %d first point %s new ring",
+ LWDEBUGF(1, "Edge %" LWTFMT_ELEMID " first point %s new ring",
e->edge_id, (contains == LW_INSIDE ? "inside" :
contains == LW_OUTSIDE ? "outside" : "on boundary of"));
@@ -2154,7 +2154,7 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
if ( contains != LW_OUTSIDE )
- LWDEBUGF(1, "Edge %d not outside of the new ring, not updating it",
+ LWDEBUGF(1, "Edge %" LWTFMT_ELEMID " not outside of the new ring, not updating it",
e->edge_id);
continue;
@@ -2163,7 +2163,7 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
if ( contains != LW_INSIDE )
- LWDEBUGF(1, "Edge %d not inside the new ring, not updating it",
+ LWDEBUGF(1, "Edge %" LWTFMT_ELEMID " not inside the new ring, not updating it",
e->edge_id);
continue;
@@ -2172,7 +2172,7 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
/* (2.3) push to forward_edges if left_face = oface */
if ( e->face_left == face )
- LWDEBUGF(1, "Edge %d has new face on the left side", e->edge_id);
+ LWDEBUGF(1, "Edge %" LWTFMT_ELEMID " has new face on the left side", e->edge_id);
@@ -2180,7 +2180,7 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
/* (2.4) push to backward_edges if right_face = oface */
if ( e->face_right == face )
- LWDEBUGF(1, "Edge %d has new face on the right side", e->edge_id);
+ LWDEBUGF(1, "Edge %" LWTFMT_ELEMID " has new face on the right side", e->edge_id);
@@ -2253,14 +2253,14 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
LWT_ISO_NODE *n = &(nodes[i]);
const POINT2D *pt = getPoint2d_cp(n->geom->point, 0);
int contains = ptarray_contains_point(pa, pt) == LW_INSIDE;
- LWDEBUGF(1, "Node %d is %scontained in new ring, newface is %s",
+ LWDEBUGF(1, "Node %" LWTFMT_ELEMID " is %scontained in new ring, newface is %s",
n->node_id, contains ? "" : "not ",
newface_outside ? "outside" : "inside" );
if ( newface_outside )
if ( contains )
- LWDEBUGF(1, "Node %d contained in an hole of the new face",
+ LWDEBUGF(1, "Node %" LWTFMT_ELEMID " contained in an hole of the new face",
n->node_id);
continue;
@@ -2269,7 +2269,7 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
if ( ! contains )
- LWDEBUGF(1, "Node %d not contained in the face shell",
+ LWDEBUGF(1, "Node %" LWTFMT_ELEMID " not contained in the face shell",
n->node_id);
continue;
@@ -2277,7 +2277,7 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
updated_nodes[nodes_to_update].node_id = n->node_id;
updated_nodes[nodes_to_update++].containing_face =
newface.face_id;
- LWDEBUGF(1, "Node %d will be updated", n->node_id);
+ LWDEBUGF(1, "Node %" LWTFMT_ELEMID " will be updated", n->node_id);
_lwt_release_nodes(nodes, numisonodes);
if ( nodes_to_update )
@@ -2324,8 +2324,8 @@ _lwt_AddEdge( LWT_TOPOLOGY* topo,
uint64_t num_nodes;
LWT_ISO_NODE *endpoints;
uint64_t i;
- int prev_left;
- int prev_right;
+ LWT_ELEMID prev_left;
+ LWT_ELEMID prev_right;
LWT_ISO_EDGE seledge;
LWT_ISO_EDGE updedge;
@@ -2429,7 +2429,8 @@ _lwt_AddEdge( LWT_TOPOLOGY* topo,
- LWDEBUGF(1, "Node %d, with geom %p (looking for %d and %d)",
+ LWDEBUGF(1, "Node %" LWTFMT_ELEMID ", with geom %p (looking for %"
+ LWTFMT_ELEMID " and %" LWTFMT_ELEMID ")",
node->node_id, node->geom, start_node, end_node);
if ( node->node_id == start_node ) {
start_node_geom = node->geom;
@@ -2874,7 +2875,7 @@ lwt_GetFaceGeometry(LWT_TOPOLOGY* topo, LWT_ELEMID faceid)
PGTOPO_BE_ERROR();
return NULL;
- LWDEBUGF(1, "lwt_GetFaceGeometry: lwt_be_getEdgeByFace returned %d edges", numfaceedges);
+ LWDEBUGF(1, "lwt_GetFaceGeometry: lwt_be_getEdgeByFace returned %lu edges", numfaceedges);
if ( numfaceedges == 0 )
@@ -3122,7 +3123,7 @@ lwt_GetFaceEdges(LWT_TOPOLOGY* topo, LWT_ELEMID face_id, LWT_ELEMID **out )
return -1;
if ( ! numfaceedges ) return 0; /* no edges in output */
- LWDEBUGF(1, "lwt_GetFaceEdges: lwt_be_getEdgeByFace returned %d edges", numfaceedges);
+ LWDEBUGF(1, "lwt_GetFaceEdges: lwt_be_getEdgeByFace returned %lu edges", numfaceedges);
/* order edges by occurrence in face */
@@ -3283,7 +3284,7 @@ lwt_ChangeEdgeGeom(LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, LWLINE *geom)
if ( ! oldedge )
LWDEBUGF(1, "lwt_ChangeEdgeGeom: "
- "lwt_be_getEdgeById returned NULL and set i=%d", i);
+ "lwt_be_getEdgeById returned NULL and set i=%lu", i);
PGTOPO_BE_ERROR();
@@ -3400,7 +3401,7 @@ lwt_ChangeEdgeGeom(LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, LWLINE *geom)
uint64_t numnodes;
nodes = lwt_be_getNodeWithinBox2D(topo, &mbox, &numnodes,
LWT_COL_NODE_ALL, 0);
- LWDEBUGF(1, "lwt_be_getNodeWithinBox2D returned %d nodes", numnodes);
+ LWDEBUGF(1, "lwt_be_getNodeWithinBox2D returned %lu nodes", numnodes);
if (numnodes == UINT64_MAX)
_lwt_release_edges(oldedge, 1);
@@ -3483,7 +3484,7 @@ lwt_ChangeEdgeGeom(LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, LWLINE *geom)
PGTOPO_BE_ERROR();
return -1;
shell = _lwt_MakeRingShell(topo, signed_edge_ids, num_signed_edge_ids);
if ( ! shell ) {
@@ -3587,7 +3588,7 @@ lwt_ChangeEdgeGeom(LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, LWLINE *geom)
PGTOPO_BE_ERROR();
return -1;
if ( ! shell ) {
@@ -3668,7 +3669,7 @@ lwt_ChangeEdgeGeom(LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, LWLINE *geom)
/* ownership transferred to faces[] */
faces[facestoupdate++].mbr = updatedBox;
- LWDEBUGF(1, "%d faces to update", facestoupdate);
+ LWDEBUGF(1, "%lu faces to update", facestoupdate);
if ( facestoupdate )
uint64_t updatedFaces = lwt_be_updateFacesById(topo, &(faces[0]), facestoupdate);
@@ -4005,7 +4006,7 @@ _lwt_RemEdge( LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, int modFace )
edge = lwt_be_getEdgeById(topo, &edge_id, &i, LWT_COL_EDGE_ALL);
if (!edge)
PGTOPO_BE_ERROR();
@@ -4119,7 +4120,7 @@ _lwt_RemEdge( LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, int modFace )
return -1;
- LWDEBUGF(1, "releasing %d updateable edges in %p", nedges, upd_edge);
+ LWDEBUGF(1, "releasing %lu updateable edges in %p", nedges, upd_edge);
lwfree(upd_edge);
/* Id of face that will take up all the space previously
@@ -5229,7 +5230,7 @@ _lwt_SnapEdgeToExistingNode(
LWT_NODE_EDGES *splitNodeEdges = lwt_nodeEdges_loadFromDB(topo, node->node_id, LWT_COL_EDGE_ALL);
if ( ! splitNodeEdges ) {
- lwerror("No edges found in DB to be incident to split node first node");
+ lwerror("No edges found in DB to be incident to split node");
return -1;
@@ -5384,6 +5385,8 @@ _lwt_SnapEdgeToExistingNode(
if ( ( replacedBy[0] != 0 && replacedBy[1] == 0 ) ||
( replacedBy[1] != 0 && replacedBy[0] == 0 ) )
+ /* One side of the snapped edge collapsed to an existing edge */
LWT_ISO_EDGE *existingEdge;
edgeend *splitNodeEdgeEndInfo;
LWLINE *newSplitEdgeLine;
@@ -5407,6 +5410,7 @@ _lwt_SnapEdgeToExistingNode(
/* TODO: check that newSplitEdgeLine part does not crosses any other edge ? */
+ /* TODO: check that newSplitEdgeLine retains its position in the edge end star (see ticket #5786) */
LWDEBUGF(1, "Existing edge %"
LWTFMT_ELEMID " (post-modEdgeSplit) next_right:%"
Summary of changes:
liblwgeom/topo/lwgeom_topo.c | 64 +++++++++++++++++++++++---------------------
1 file changed, 34 insertions(+), 30 deletions(-)
hooks/post-receive
