[SCM] PostGIS branch master updated. 3.5.0-19-gcfc46e464
git at osgeo.org
git at osgeo.org
Fri Oct 11 00:59:07 PDT 2024
the project "PostGIS".
via cfc46e4641c1fa7b3b391e3846ae3a2f79cd07b7 (commit)
from b0f0182dc0a8157e2da3d411165eac0113631799 (commit)
revisions in full, below.
commit cfc46e4641c1fa7b3b391e3846ae3a2f79cd07b7
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Oct 11 09:47:27 2024 +0200
Fix crash in TopoGeo_addPoint
References #5794 in master branch (3.6.0dev)
Includes regress test
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index bfdcf137e..cf869bb1a 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -6427,7 +6427,7 @@ _lwt_SnapEdgeToExistingNode(
* @param moved if not-null will be set to 0 if the point was added
* w/out any snapping or 1 otherwise.
- * @return id of the new node or -1 on error
+ * @return id of the new node, 0 if no edge was found below tolerance or -1 on error
static LWT_ELEMID
@@ -6454,6 +6454,12 @@ _lwt_SplitAllEdgesToNewNode(LWT_TOPOLOGY* topo, LWT_ISO_EDGE *edges, uint64_t nu
sorted[j].ptr = e;
sorted[j++].score = dist;
+ if ( ! j )
+ lwfree(sorted);
+ return 0;
num = j;
qsort(sorted, num, sizeof(scored_pointer), compare_scored_pointer);
edges2 = lwalloc(sizeof(LWT_ISO_EDGE)*num);
@@ -6760,7 +6766,8 @@ _lwt_AddPoint(LWT_TOPOLOGY* topo, LWPOINT* point, double tol, int
id = _lwt_SplitAllEdgesToNewNode(topo, edges, num, lwgeom_as_lwpoint(pt), tol, moved);
_lwt_release_edges(edges, num);
- else
+ if ( id == 0 )
/* The point is isolated, add it as such */
/* TODO: pass 1 as last argument (skipChecks) ? */
diff --git a/topology/test/regress/topogeo_addpoint.sql b/topology/test/regress/topogeo_addpoint.sql
index 1d5ad1894..a454cc711 100644
--- a/topology/test/regress/topogeo_addpoint.sql
+++ b/topology/test/regress/topogeo_addpoint.sql
@@ -78,3 +78,11 @@ SELECT 't5698', 'E', TopoGeo_addLinestring('t', 'LINESTRING( 15.796760167740288
SELECT 't5698', 'N', TopoGeo_addPoint( 't', 'POINT(15.796760167739626 69.05714853429157)');
SELECT 't5698', 'V', * FROM ValidateTopology('t');
SELECT NULL FROM DropTopology('t');
+-- See https://trac.osgeo.org/postgis/ticket/5794
+BEGIN;
+SELECT NULL FROM topology.CreateTopology ('t');
+SELECT NULL FROM topology.TopoGeo_addLinestring('t', 'LINESTRING(0 0, 10 0)');
+SELECT 't5794', 'N', topology.TopoGeo_addPoint('t', 'POINT(9 5)', 5);
+SELECT 't5794', 'V', * FROM ValidateTopology('t');
+ROLLBACK;
diff --git a/topology/test/regress/topogeo_addpoint_expected b/topology/test/regress/topogeo_addpoint_expected
index bf28121eb..727560e08 100644
--- a/topology/test/regress/topogeo_addpoint_expected
+++ b/topology/test/regress/topogeo_addpoint_expected
@@ -32,3 +32,4 @@ tt5394|E2|2
tt5394|N|3
t5698|E|1
t5698|N|3
+t5794|N|3
Summary of changes:
liblwgeom/topo/lwgeom_topo.c | 11 +++++++++--
topology/test/regress/topogeo_addpoint.sql | 8 ++++++++
topology/test/regress/topogeo_addpoint_expected | 1 +
3 files changed, 18 insertions(+), 2 deletions(-)
hooks/post-receive
