[SCM] PostGIS branch stable-3.5 updated. 3.5.0-10-g0b55ff427
git at osgeo.org
git at osgeo.org
Fri Oct 11 01:02:58 PDT 2024
the project "PostGIS".
The branch, stable-3.5 has been updated
via 0b55ff4279d1b30d17b1e520ef8b5d466cdfd8e9 (commit)
from 31993531006d95721bed3328d0d511e9d91f102e (commit)
revisions in full, below.
commit 0b55ff4279d1b30d17b1e520ef8b5d466cdfd8e9
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Oct 11 09:47:27 2024 +0200
Fix crash in TopoGeo_addPoint
Closes #5794 in 3.5 branch (3.5.1dev)
Includes regress test
diff --git a/NEWS b/NEWS
index fd090c86d..60e268649 100644
--- a/NEWS
+++ b/NEWS
@@ -6,6 +6,7 @@ PostgreSQL 12-17 required. GEOS 3.8+ required. Proj 6.1+ required.
* Bug fixes *
+- #5794, Fix crash in TopoGeo_addPoint (Sandro Santilli)
- #5785, [raster] ST_MapAlgebra segfaults when expression references
a supernumerary rast argument (Dian M Fay)
- #5787, Check that ST_ChangeEdgeGeom doesn't change winding of rings
@@ -52,9 +53,9 @@ Andreas Schild (German Team)
will need rebuilding to upgrade to new signature
(Jan Tojnar)
- #5496, ST_Clip all variants replaced, will require
- rebuilding of materialized views that use them
+ rebuilding of materialized views that use them
(funding from The National Institute for Agricultural
- and Food Research and Technology (INIA-CSIC)),
+ and Food Research and Technology (INIA-CSIC)),
Regina Obe)
- #5659, ST_DFullyWithin behaviour has changed to
be ST_Contains(ST_Buffer(A, R), B) (Paul Ramsey)
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index bfdcf137e..cf869bb1a 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -6427,7 +6427,7 @@ _lwt_SnapEdgeToExistingNode(
* @param moved if not-null will be set to 0 if the point was added
* w/out any snapping or 1 otherwise.
- * @return id of the new node or -1 on error
+ * @return id of the new node, 0 if no edge was found below tolerance or -1 on error
static LWT_ELEMID
@@ -6454,6 +6454,12 @@ _lwt_SplitAllEdgesToNewNode(LWT_TOPOLOGY* topo, LWT_ISO_EDGE *edges, uint64_t nu
sorted[j].ptr = e;
sorted[j++].score = dist;
+ if ( ! j )
+ lwfree(sorted);
+ return 0;
num = j;
qsort(sorted, num, sizeof(scored_pointer), compare_scored_pointer);
edges2 = lwalloc(sizeof(LWT_ISO_EDGE)*num);
@@ -6760,7 +6766,8 @@ _lwt_AddPoint(LWT_TOPOLOGY* topo, LWPOINT* point, double tol, int
id = _lwt_SplitAllEdgesToNewNode(topo, edges, num, lwgeom_as_lwpoint(pt), tol, moved);
_lwt_release_edges(edges, num);
- else
+ if ( id == 0 )
/* The point is isolated, add it as such */
/* TODO: pass 1 as last argument (skipChecks) ? */
diff --git a/topology/test/regress/topogeo_addpoint.sql b/topology/test/regress/topogeo_addpoint.sql
index 1d5ad1894..a454cc711 100644
--- a/topology/test/regress/topogeo_addpoint.sql
+++ b/topology/test/regress/topogeo_addpoint.sql
@@ -78,3 +78,11 @@ SELECT 't5698', 'E', TopoGeo_addLinestring('t', 'LINESTRING( 15.796760167740288
SELECT 't5698', 'N', TopoGeo_addPoint( 't', 'POINT(15.796760167739626 69.05714853429157)');
SELECT 't5698', 'V', * FROM ValidateTopology('t');
SELECT NULL FROM DropTopology('t');
+-- See https://trac.osgeo.org/postgis/ticket/5794
+BEGIN;
+SELECT NULL FROM topology.CreateTopology ('t');
+SELECT NULL FROM topology.TopoGeo_addLinestring('t', 'LINESTRING(0 0, 10 0)');
+SELECT 't5794', 'N', topology.TopoGeo_addPoint('t', 'POINT(9 5)', 5);
+SELECT 't5794', 'V', * FROM ValidateTopology('t');
+ROLLBACK;
diff --git a/topology/test/regress/topogeo_addpoint_expected b/topology/test/regress/topogeo_addpoint_expected
index bf28121eb..727560e08 100644
--- a/topology/test/regress/topogeo_addpoint_expected
+++ b/topology/test/regress/topogeo_addpoint_expected
@@ -32,3 +32,4 @@ tt5394|E2|2
tt5394|N|3
t5698|E|1
t5698|N|3
+t5794|N|3
Summary of changes:
NEWS | 5 +++--
liblwgeom/topo/lwgeom_topo.c | 11 +++++++++--
topology/test/regress/topogeo_addpoint.sql | 8 ++++++++
topology/test/regress/topogeo_addpoint_expected | 1 +
4 files changed, 21 insertions(+), 4 deletions(-)
hooks/post-receive
